- 6 Jan 2013
- Rollergirl
Got a Zotac Amp Extreme coming!! Ordered today, does dpd deliver saturday?
Yes.
It's great, I can run mine with 1535/8000 and have 73,7, you should be at least up there.74.4 Is that ok?
Eeee ordered my msi for Saturday, had to pay extra 10 for that as couldn't use prime, just missed out on the stock!
Any game suggestions? Gta 5 and witcher 3 I plan to play, also battlefield 4. What others?
So really, why isn't Galax pushing the fact they use binned chips? Everyone is running 72%+ Asic.
So, what's the best 980Ti available now? I was looking at the EVGA Hybrid, it's a reference design though I think so maybe something with a non-reference design with 3 fans would be better?
Dont worry one of my EVGA SC is 63% ASIC. but still overclocks with a custom bios to 1550MHZ thats +360mhz on the core clock. stated in unengine valley as 1743mhz. Only use GPU-Z, afterburner exaggerates.
Shiny.
Shiny.
Put in a 120mm fan (Set to lowest RPM) in bottom of node 804 and dropped 980 Ti temps by about 10C, wasn't expecting that big of a difference tbh![]()
My kit in the Define S is doing really well too. CPU being cooled by the H110i intaking from the front, the bottom fan is cooling the bottom Ti and the side fan is cooling the top Ti!! With one on the rear for extraction it's a pretty good setup tbh
Everything is doing reallllllllly weell temp-wise. Chuffed!!!
Only thing I have to sort is to try to get the idle sound down a touch, but it's not like it's intrusive. I crave complete silence
Just a lot of airflow going on![]()
Value for money wise, the 8 Pack HOF Edition is hard to beat, binned GPU's, great power phase and a decent and sexy cooling solution.![]()
