One thing I have dislike about my Civic is the amount of rust on the parts of the discs that are not swept by the pads.
I am planning a brake overhaul to include new hoses, discs, pads and fluid along with painting the callipers. Are there any discs out there that resist rust well?
I'm not looking for anything drilled or grooved, just a decent disc that will look good over its lifetime. I have seen compatible discs from the likes of MTEC, Fedoro, Brembo, Pagid and Bosch. Can anyone recommend a particular brand?
. On a more serious note, it looks like a 10 mil gap between the used part of the disc and the edge, is that right? On every car I've seen it's more like a couple of mill or is it just the camera angle?
