Ashes of the Singularity Coming, with DX12 Benchmark in thread.
Caporegime
17 Mar 2012
ARC-L1, Stanton System
What should you expect out of a non-synthetic benchmark?
But what is it exactly that you are going to see in a benchmark that is measuring actual gameplay performance? If you run the Ashes of the Singularity Benchmark, what you are seeing will not be a synthetic benchmark. Synthetic benchmarks can be useful, but they do not give an accurate picture to an end user as to what expect in real world scenarios.
Our benchmark run is going to dump a huge amount of data which we caution may take time and analysis to interpret correctly. For example, though we felt obligated to put an overall FPS average, we don’t feel that it’s a very useful number. As a practical matter, PC gamers tend to be more interested the minimum performance they can expect.
People want a single number to point to, but the reality is that things just aren’t that simple. Real world test and data are like that. Our benchmark mode of Ashes isn’t actually a specific benchmark application, rather it’s simply a 3 minute game script executing with a few adjustments to increase consistency from run to run.
What makes it not a specific benchmark application? By that,we mean that every part of the game is running and executing. This means AI scripts, audio processing, physics, firing solutions, etc. It’s what we use to measure the impact of gameplay changes so that we can better optimize our code.
Because games have different draw call needs, we’ve divided the benchmark into different subsections, trying to give equal weight to each one. Under the normal scenario, the driver overhead differences between D3D11 and D3D12 will not be huge on a fast CPU. However, under medium and heavy the differences will start to show up until we can see massive performance differences. Keep in mind that these are entire app performance numbers, not just graphics.
http://oxidegames.com/2015/08/16/the-birth-of-a-new-api/
Benchmarks.
PCPer
http://www.pcper.com/reviews/Graphi...ted-Ashes-Singularity-Benchmark/Results-Avera
There is a lot of information in each graph so be sure you are paying attention closely to what is being showcased and what bars represent what data. This first graph shows all the GPUs, resolutions and APIs running on the Core i7-5960X, our highest end processor benchmarked. The first thing that stands out to me is how little different there is between the DX11 and DX12 scores on the NVIDIA GTX 980 configuration. In fact, only the 1080p / Low preset shows a performance advantage at all for DX12 over the DX11 in this case; the other three results are showing better DX11 performance!
The AMD results are very different – the DX12 scores are as much as 80% faster than the DX11 scores giving the R9 390X a significant FPS improvement. So does that mean AMD’s results are automatically the better of the two? Not really. Note the DX11 scores for the GTX 980 and the R9 390X – at 1080p / Low the GTX 980 averages 71.4 FPS while the R9 390X averages only 43.1 FPS. That is a massive gap! After utilizing the DX12 that comparison changes to 78.3 FPS vs 78.0 FPS – a tie. The AMD DX12 implementation with Ashes of the Singularity in this case has made up the difference of the DX11 results and brought the R9 390X to a performance tie with the GTX 980.
Computerbase
http://www.computerbase.de/2015-08/...diagramm-ashes-of-the-singularity-3840-x-2160
Eurogamer
http://www.eurogamer.net/articles/digitalfoundry-2015-ashes-of-the-singularity-dx12-benchmark-tested
DidgitalFoundry
Wccftech
NVIDIA: We Don’t Believe AotS Benchmark To Be A Good Indicator Of DX12 Performance
http://wccftech.com/nvidia-we-dont-believe-aots-benchmark-a-good-indicator-of-dx12-performance/
'Nvidia mistakenly stated that there is a bug in the Ashes code regarding MSAA. By Sunday, we had verified that the issue is in their DirectX 12 driver. Unfortunately, this was not before they had told the media that Ashes has a buggy MSAA mode. More on that issue here. On top of that, the effect on their numbers is fairly inconsequential. As the HW vendor's DirectX 12 drivers mature, you will see DirectX 12 performance pull out ahead even further.'
We've offered to do the optimization for their DirectX 12 driver on the app side that is in line with what they had in their DirectX 11 driver. Though, it would be helpful if Nvidia quit shooting the messenger.
http://forums.oxidegames.com/470406
I'm looking forward to this one. I love strategy games the most :) .
I'm sure it will perform great too and did AMD not show it running at that presentation back in June.
This is the important paragraph for me. :)
Being fair to all the graphics vendors
Often we get asked about fairness, that is, usually if in regards to treating Nvidia and AMD equally? Are we working closer with one vendor then another? The answer is that we have an open access policy. Our goal is to make our game run as fast as possible on everyone’s machine, regardless of what hardware our players have.
To this end, we have made our source code available to Microsoft, Nvidia, AMD and Intel for over a year. We have received a huge amount of feedback. For example, when Nvidia noticed that a specific shader was taking a particularly long time on their hardware, they offered an optimized shader that made things faster which we integrated into our code.
We only have two requirements for implementing vendor optimizations: We require that it not be a loss for other hardware implementations, and we require that it doesn’t move the engine architecture backward (that is, we are not jeopardizing the future for the present).
Notice how AMD haven't suggested that any shaders are taking longer on their hardware...because they haven't bothered running it yet..much like pcars!! :D
I jest, only time will tell :)
I wouldn't say that. AMD Hardware was used to showcase the game in the firstplace :P I think it is also an AMD sponsored game.
They felt a need to make a point of being unbiased, Did some optimizations cripple the competition? :D
On a serious note i'm looking forward to some DX12 stuff.....
LOL! Many a true word said in jest ;) :D
Well the nVidia driver is already out for this, wonder when AMD will release theirs. December? :p
Its going to be interesting, but I can imagine which ever team turns out to be slower, there will be cries of 'its not a fair test because XYZ'.
Fun times ahead. :)
