- 29 Dec 2014
- The "North"
Thanks, I'm not sure how long to leak test for but I think 24 hours should do the trick after I've filled it todayLooking good and fingers crossed for no wet patches today![]()
Yeah, I tripple checked the tubing was inserted correctly as sometimes if not they can pop out with little force. Luckily they all fit in snugNice work on the tubing man. Just be extra sure to make sure all the tubing is correctly seated in the fittings. I pushed mine in until I though they were good but once I turned the pump on I was getting leaks everywhere! You have to push them to the point you think they're gonna break nearly!
