19 Aug 2015 at 07:40 #1 Cheetah Designs Cheetah Designs Associate Joined 10 Jul 2006 Posts 2,423 I have a Surface Pro 3 and it hasn't been auto-upgraded yet, when do the auto upgrades start?
19 Aug 2015 at 10:50 #2 Memphis Memphis Soldato Joined 13 Jan 2004 Posts 12,197 Location Inverness They started on the 29th of last month. Is the device fully updated and you have the Windows logo saying you're reserved and waiting? Just manually kick off the upgrade with the media creator.
19 Aug 2015 at 11:09 #3 Cheetah Designs Cheetah Designs Associate OP Joined 10 Jul 2006 Posts 2,423 Yes and yes. How do I kick it off manually?
19 Aug 2015 at 11:19 #4 Elevon Elevon Soldato Joined 22 Sep 2006 Posts 3,465 Cheetah Designs said: Yes and yes. How do I kick it off manually? Click to expand... http://windows.microsoft.com/en-gb/windows-10/media-creation-tool-install
20 Aug 2015 at 07:44 #5 Cheetah Designs Cheetah Designs Associate OP Joined 10 Jul 2006 Posts 2,423 Is it best to do a clean install? Do I gain/loose anything?
29 Aug 2015 at 16:37 #6 Mel_P Mel_P Soldato Joined 27 Feb 2004 Posts 2,577 Location Kent You can only do a clean install once you have been through the upgrade process. For a clean install without the upgrade first you need to buy Win 10
