http://www.coolermaster.com/case/mid-tower/mastercase5-series/?ref=MC5EL
Looking to replace my HAF 912+ in a couple of months,.
Been looking at this case myself. Reviews are coming in good.
I got really excited that this would be a return to the ATC range level of quality, alas not.![]()
I missed brushed aluminium, over engineered chassis and car body work level paint finishes.
Ever thought about a Phanteks case? The pro and luxe are two well priced feature packed cases. Build quality of phanteks cases is pretty good too.
I'd be looking at Phanteks too.
After Computex I was super-pumped for the mastercase but as it took so long to release I cooled off. As per the OC3D review, the price is a fair turn-off as is the lack of upgrade options. I really liked the look of the tempered glass panel which unfortunately isn't available yet (if it ever will be).
I have gone for an mATX build instead but if I was looking at ATX I'd probably go with a Phanteks case.
There are plans for a lot of different accessories, this isn't just one product with the occasional item, but a whole range of items in the MasterCase range, with interchangeable and community inspired upgrades and ideas. Like tempered glass side panels, aluminium finishes, GPU support brackets, HDD cages, reservoir mounts, interchangeable front panels with USB Type C or a card reader or even USB over 9000 when it comes out, different panel finishes and colours. All interchangeable between MC5 models and some interchangeable with up coming things. I could go on.... This isn't about just one product and what you see now, this is our company ethos and a long term products.
I think it looks nice just a bit cheap looking. Im sure if they sold a "Elite" version with tempered glass front and side it would look a lot more expensive.
https://www.overclockers.co.uk/showproduct.php?prodid=CA-366-CM&groupid=2362&catid=29
https://www.overclockers.co.uk/showproduct.php?prodid=CA-367-CM&groupid=2362&catid=29
Now available to preorder guys. Stock due around 1st September.
