- 30 Nov 2011
I also just thought of something else, The Temporal AA has a massive amount of cpu overhead from what i remember. if it used the same type as starswarm.
When i disabled that in star swarm i went from low double digits to over 30 fps.
so even on high settings and with heavy draw calls, the more CPU limited benchmarks could get a good boost in performance.
Yes, if they are still plugging that "movie quality motion blur" of theirs - iirc FPS more than doubled when it was turned off in star swarm, completely pointless option imo
if the game was running at 200fps and turning it on brought it to 100fps then yeah fair enough, but if the game is running at 30fps and turning it off means consistently well above 60 then I really can't see anyone wanting to use it
