I have seen a couple that start with a pea sized amount then spread it with a card....
x method I assume is just do an x and then place the heatsink on it?
I've always used the pea sized blob before but decided to try a small X this time round.
It seems okay, running around 31-32 in the bios despite the heat the past few days. On the other hand I'd hope for good temps with my cooler and I've not actually done any oc-ing yet. I just can't shake the feeling I've used too much and have to keep resisting the urge to take it off and have a look. I'll see what the temps look like after I try to oc.
One thing I did this time round after the I botched the first application was to just hold the TIM syringe in my palm for about 30 seconds. It warmed up the MX-4 enough to get a nice, smooth and clean amount out and hopefully helped the initial spread too.
I might start a new thread, 7 years ago was last time i built a pc and applied paste, i just used the spread with a card method, aint this the same as useing the pea blob in middle, and letting the heatsink spread it, as both ways spread the paste over the chip, at least with the credit card way you know you have spread it all over correctly, doing the blob pressure way, might not cover it correctly if you used to small amount, or if you use to much it goes all over the sides ? dont anyone still just use the spread method with card anymore ? oh and i have a skylake i7 6700K chip, and they look very small compared to other chips, would people still apply useing the same method ?
Ah ok, i guess i just need to judge how much paste to put on a 6700K then, i would just be worried that when i use heatsink to do the job, it might not spread over the whole surface.
You do know how big a pea is right?
I think the paste is supposed to go on the chip, not around the outside of it!![]()
remember, we have all been useing it for like 20 years before with no problem
Just about to install a 5820k.
Always used "grain of rice" (smaller than pea!) method in the paste.
