Gigabyte X99-sli bios issue.
29 Feb 2004
I got a 5820K + GA-X99-SLI board last week and have been having an issue with the bios. I've found the cause, but have no idea how to fix it.
Basically the issue is, it simply won't enter the bios. It just hangs on a black screen before, then the monitor goes to sleep.
I've found the issue. Apparently it is one of my 2TB western digital greens. Unplug it and it goes into bios 100% of the time. Plug the western digital in and it hangs 9/10 times. The other 2TB drive (same model is fine).
It's 100% fine in windows, everything is detected,all works fine. The computer posts fine 100% of the time. The only issue is, it simply refuses to go into the bios with the drive attached. The drive is fine on others pcs, it's literally just this one that will not go into bios with it attached.
I can always unplug the drive go to bios tweak what I want and come out and plug it back in but that's not really a solution.
Any ideas?
I know of a fix that worked on x99,it seemed the bios didn't like booting when more than one mbr hdd was attached,if you format the hdd and create it in gpt then it should bootup fine with the two hdd's pluged in
Didn't realise there were other issues, so I should mention the two 2tb are not the only drives.
There is an ssd and another mechanical drive ( a segate). There is no problem booting into windows either, or the system post. It just won't go into the bios.
I've tried swaping the cables. Swapping the ports (different hdd on that sata port, the problem one on another). Tried the problem one by itself.
It does not matter the combination. Even alone on any port, if that 2TB is connected, it will not let me into the bios. The drive is fine on other systems, it just this board.
Yeah its down to two HDDs being MBR partition,if you make one of the HDDs a gpt partition it should let you access the BIOS with all HDDs attached
Or make the problematic HDD gpt then see if you can access the BIOS
I've seen this before
If that doesn't fix it then idk,its a BIOS bug that needs addressing
Not had a chance to try it yet. I'll give formatting the problem drive to gpt a go see if that fixes it then.
Although I don't think it's the more than one being mbr. All the other drives are mbr and I can get into bios with them all connected at the same time.
I can't get into the bios with the drive with issue, even when it's connected alone. So nothing else with mbr.
I'll still give gpt a shot as I won't lose data though.
it might be a bios bug with that make/model of hdd
try gpt first though it might be a work around till they release updated bios
Will try gpt later. Although now I think of it, the drive that hangs the bios, is one I had issues before with.
forums.overclockers.co.uk/showthread.php?t=18588833
Wouldn't play nice with amd controller, but fine on JMB362.
Was bought later than the other one that is fine, so now I've remembered that, thinking it might be a crappy/different firmware on the drive. Will try GPT though, then maybe see if firmware can be updated (not sure on that drive).
Having almost bought one of these the other day, there seems to be a lack of BIOS updates from Gigabyte on this
Yeah, there is only the f2 beta bios :(.
To be completely fair, considering the other issue I had with the same drive (not playing nice on the amd controller), it's probably some dodgy firmware western digital stuck on it (I have 3 2TB drives, only one has the issue and was bought at a much later date).
Only other issue I've had is usb 3 + a certain device (got another thread on that), but then looking online, usb 3 issues seem common across many boards + hardware combos and looking at the requirements of some devices that use it (capture cards etc), it seems usb3 is not as universal as the name would imply.
I did only pay what was essentially £100 for the board (5820k + mb bundle on here when it was cheaper), I guess I might be a bit more annoyed if I had paid the £180 the board normally is.
Picked up one of these recently for new/rebuild on the Today's Deals offers. Just requested to RMA it back. Not detecting any fans connected to the MB (but powers them) and most of the time on start up it severely underclocks the CPU at 800Mhz-1.2GHz. Have to go into the BIOS and just save and exit just to get it to run at stock.
So far very disappointed nothing but issues getting this board to run properly for over a week however when it does run its rock solid.
Hope I just go one slightly dodgy board and a replacement will be OK.
Underclocking the cpu is called Intel Speedstep and is normal thing to do at idle to save power, when its needed the CPU will ramp up to the correct speeds.
As for the fans are you sure they were plugged in correctly.
Do you mean in the bios they are not detected? or using third party stuff from within windows?
HWmonitor for example, doesn't read stuff right. The two fans it pulls are case fans and it ignores the cpu fan.
Gigabyte's own software and bios does show them all though, so if it's the bios/their software, then I guess yours is faulty :(.
Its not SpeedStep, its showing max 800Mhz to 1.2GHz and staying there (sometimes boots at 800Mhz and sometimes at 1.2GHz), running very slowly and not going above that speed, system takes ages to fully boot. When I go into the BIOS and just save and exit sometimes it boots with speeds correct and runs a 3.3GHz with SpeedStep running between 1500MHz (at idle), full speed and 3.6GHz Turbo if i push it.
Have CPU and a system fan plugged into it and nothing in the BIOS, both fans show zero RPM's. Also show zero in the Gigabyte System Information viewer and going into the SIV app have tried the calibrate option under Smart Fan Advanced and still nothing.
Yeah tried the only other BIOS - F2a and same, also tried going back to the original and same. Can't find anyway of switching to the backup BIOS, I think that's only for when the main BIOS fails.
Also tried downloading BIOS from a different gigabyte server in case its corrupt - no change (can you tell i've been getting desperate) :)
Also flashed through windows app and QFlash - no change. Looks like I have a hardware issue.
Was set to Balanced. Changed it to high Performance and rebooted - bang crash in POST and back into BIOS recovery. Went into BIOS - loaded Optimized Defaults - saved and exit. Booted but very slow - tried to open CPU-Z to take a screenshot and system crashed
Rebooted again - slow CPU again. Back into BIOS - Saved and exit and now running at stock 3.3GHz.
Sounds like hardware issue.
I have the splash screen on, but when I didn't, I'm pretty sure it showed cpu at 3.3 on boot. Full speed when I go into bios as well. I've certainly never had any slow boot or other issues. I am on the F1 bios.
Is this a fresh install? you aint trying to just reuse an install from a previous ancient motherboard combo and thus getting Windows in a right mess?
Thanks
Yeah BIOS always shows the correct speed just when it boots into Windows 8 times out of 10 it runs the CPU very slow and takes ages. Never seen anything like this before and been building PC's (for me and my sons) for years. Got me completely flummoxed.
Did think it could have been a PSU issue but I'm running an EVGA 1300w which should be plenty and when I do boot at 3.3GHz its rock solid. Been running all day today with no issues but when I reboot or cold boot I have the issues and then it takes several boots to get it up to speed. Took out one video card (280x's are very power hungry) and tried my old Antec 900w and it was exactly the same.
