The ASIC benching thread.
The purpose of this thread is to compare the following
ASIC
Max Boost
Temp
Voltage Used
If we can get a good range of results we can see if there are any trends with ASIC quality.
In the next post are the settings and software to be used, please do not submit any results using anything else as it will not be counted as we all need to use the same for this to work.
ASIC
Max Boost
Temp
Voltage Used
