- 5 Sep 2011
- Surrey
Stock and bios and voltage would make more sense here Kaap
I don't think stock setting will show anything important as all the numbers will be near enough the same for any given card series.
It's all or nothing as you push the card to the limit and see how far your asic % takes you. In my case, not very far![]()
Hi, I hope this is sufficient, took the picture before realising you wanted a picture of the start screen:
Gigabyte G1 Gaming 980Ti
ASIC - 72.8%
GPU Clock - 1320MHz
Set Boost - 1409MHz
Max Boost - 1560MHz
Max Temp - 60c
Max VDDC - 1.243v
The highest maximum clock you can manage without breaking anything.![]()
that's a very good max boost on that G1
happy days
