- 13 Jul 2004
- Stanley Hotel, Colorado
Kill some bots first, couple hundred only takes 5 mins so its quicker them dm. Isnt mm capped to LE at first anyhow
I came from pre 1.0 (actually retail brought all the pleb masses, we thought the game/servers were ruined tbh) and I think it was 800x600 I had or lower on 14" CRT. My first cs game, literally no 3d graphics card installed. It was pure cpu back then, polygons going to the FPU on the CPU.
16:9 or 4:3 does feel different though. If you change up you should reevaluate your sens, crosshair.
I play 450dpi 1.81 sens 1024x768 or 1.54 sens on 800x600 and 640x480 is doable but I'd be surprised anyone at all felt it was best. I think scream is 800x600 but only when streaming games otherwise higher res
I think the ideal is 128tick 300-250fps min 1080p 144hz and dont play anything else
Play NA servers if solo a lot, radical idea as that is I think theres nothing to lose its worth trying once. MM will match your ping to someone from texas playing on nyc servers fairly often
I think a lot of AA helps on lower res but the head hitbox is only like 1 pixel, it must be a disadvantage I guessSo what res is everyone using? I'm currently using 1920x1080 on a 24'' BenQ 120Hz I wish I could run lower however I struggle to actually see long distance :/
I'd still say no matter how old school, upgrade your res if you can but go as close to 300fps as possible.I'd say unless you've come from 1.6 and stuck to that res all the time just play with your native.
Noticed a few more from casual games banned just after their rank 3, seems its doing an ok jobNot allowing under R3 players on competitve has improved things so much - actually winning games now based on skill, not just who has a paddy and leaves.
I haven't played for a few years and got back into it and it's kept me the same rank as before and I'm struggling with the comp matches. So far I've won 1 out of 3. I also seem to get lumped with Russians who just rush in.. meh :/ casual games are a bit easy so there's no in between for me at the moment![]()
