... 1600w power supply? How overkill are you going exactly? I think a 4 way Titans (on their own of course) use something like 900W, you don't need 1600W at all, save £100 and get 1200W.
Also in your build the case is Black/Orange, not Black/Red, which I believe is the one you want.
Also I just realised I can't read.
Apart from 2 cases it seems fine and will work together.
No the Gigabyte one, think the ASUS does 4X PCI-E3.0 to the m.2 so is ok.
The Intel 750 PCI-E SSD would work with the Gigabyte ok I am 100% sure about.
do you think the intel drive is better than the samsung sm951
They are in some situations but probably not noticeable side by side apart from benchmarks that test SSD read/writes at various queue depths.
I think this would be just as quick while a fair bit less,
YOUR BASKET
1 x Intel i7-5960X Extreme 3.00GHz (Haswell-E) Socket LGA2011-V3 Processor - Retail (BX80648I75960X) £799.99
2 x Gigabyte GeForce GTX 980Ti G1 Gaming 6144MB GDDR5 PCI-Express Graphics Card £599.99 (£1,199.98)
1 x Intel 750 Series 400GB PCIe 3.0 X4 HHHL Adaptor NVMe Solid State Drive (SSDPEDMW400G4X1) £319.99
1 x Crucial BX100 1.0TB SSD SATA 6Gbps 7mm Solid State Drive (CT1000BX100SSD1) £289.99
1 x Avexir Core Red Series 32GB (4x8GB) DDR4 PC4-21300C15 2666MHz Quad Channel Kit (AVD4U26661508G-4CIR) - Red Light £278.99
1 x Gigabyte X99-Gaming 5P Intel X99 (Socket 2011) DDR4 ATX Motherboard £229.99
1 x EK Water Blocks Predator 360 All In One Watercooling Solution £202.99
1 x Phanteks Enthoo Primo Full Tower - Black/Red £199.99
1 x EVGA SuperNova P2 1000W '80 Plus Platinum' Modular Power Supply (220-P2-1000-XR) £161.99
1 x CableMod E-Series G2 & P2 Cable Kit - Black / Orange £69.95
1 x Pioneer BDR-S09XLT 16x BluRay / 16x DVD±RW 50GB Drive - Black (Retail) £64.99
Total : £3,818.84 (includes shipping : Ex.VAT).
Corsair H100i GTX, H110i GT
Or OcUK tech labs - https://www.overclockers.co.uk/showproduct.php?prodid=BU-098-TL&groupid=701&catid=2330&subcat=2996
Make sure you pick the right socket fitting for it and select a fan controller to plug the fans into as it will otherwise use up 4 fan headers (one pump and three fans).
