Tape storage, what's the word?
26 May 2009
In the process of migrating to Windows Server Essentials with Office 365 (Office already running) and was looking at new backup software (Backup Exec 12.5 isn't supported on WSE, seems only yesterday we upgraded to 12.5 lol) and thought I would also look at whether it's worth moving from SDLT to something else like LTO at the same time.
Whats going on in the world of backups?
We use LTO 5 & now 6 in work to backup video footage. We used to use Backup exec 2012 with LTO 5 primarily because the SAS HBA in the server didn't support LTFS. Since migrating the tape drive to a new server, we now use LTFS only. Nice and simple process with no additional software required. I haven't had much time to play with LTFS myself but from what I did find out, there is an xml file that details the contents of the tape which can be used to log what data ended up on what tape.
For that amount I wouldn't even be thinking about Tape (unless there is a specific requirement to archive for 20 years or Insurers specify backups must be to Tape).
256GB or even 512GB USB3.0 flash drives are affordable and offer decent backup performance, or even SSDs in USB3 or esata enclosures?
Tape has pretty much been replaced by disk based solutions. Although your backup requirements are a little small for purchasing these types of solutions. I would echo the above and purchase some large usb3 sticks.
Current system is a GFS rotation, or was, we only do the daily/weekly backups now as recession cost cutting ended the stockpiling of monthly backups.
Are USB3 sticks supported by backup software? Not trying to be rude but it sounds kind of like a bodge (or maybe it just sounds odd as I haven't heard of it before). Looking at the cost of USB3 Sticks they are a lot more than tapes so the whole setup would prob rival tapes+drive for cost.
I'll be honest, in my business environment it is a low tech solution (not quite a bodge), with robocopy and direct copies of files consolidated from several servers, but I back up 50GB daily in under an hour.
The speed and portability is the main win for me - easy and quick to restore individual files, and no requirement to have a tape drive to access the backups (e.g. if the site was destroyed by fire - I can plug USB drives into any PC)
Backup Exec 2010 R2 onwards seem to support USB Disks e.g.
https://support.symantec.com/en_US/article.HOWTO55855.html
If you don't want to spend too much money, external hard drives would be pretty cheap - i.e. same result as USB sticks, but cheaper. USB3 probably a good move though.
I'm not really sure why you'd want to muck around with tapes for such a small amount of data.
I agree with this. The only downside I can see is if they need swapping daily, then the connectors mightn't be up to it. For a simple DR solution I tend to suggest a couple of these: Western Digital Passport They work well with the MSE/Server 2012 onwards built-in backup software. You can enable the WD security and encrypt them with it automatically unlocking the drives when they're plugged in.
That's true. In similar circumstances I used a NAS in a different building (but on the same internal network), which got around the frequently connecting / disconnecting problem.
Thanks dude, looked into that and it seems like a great option. I had been considering LTO-3 400/800GB (as it's cheaper than SDLT 300/600GB lol).
Not sure why you would be considering LTO-3 given how old it is now (how long will you be able to get drives for that can read LTO-3, LTO-6 is current and shouldn't still read LTO-3, LTO-7 is arguably due any time)?
The only thing I can see going for LTO-3 is cheap media cost, but that's only good whilst you can still read it :)
Surely you want to be looking at LTO-6?
LTO-6 is a bit overkill lol, the drive will probably fail before it becomes worth it over RDX.
To put it in perspective we moved from DDS-2 to DDS-5 (DAT72) in 2004, then to SDLT 160/320 in 2010, I really don't see 2.5TB being required anytime soon.
It's not about the capacity though? And the cost difference for the drive is around £200.
The question is longevity - yes you can still buy an LTO-3 or LTO-4 (read/write LTO-3 media) drive now, but will that be the case when the drive fails and you need another?
Not sure why you would purposely buy obsolete, other than to save a few quid (which when relating to backups, I would rather not skimp)
If you don't need the capacity and are worried about media costs, then use LTO-5 tapes (quick look these are much cheaper ~£15 each vs ~£40, LTO-5 tapes look to be about the same price as LTO-3) with an LTO-6 drive.
Yeah, that's basically it, spending extra to get something you know you will not be needing is false economy. I.E I buy an LTO-6 drive now, I have spent more than I would on an LTO-3 drive, and when it dies that money will essentially have been wasted and I then have to choose between buying another LTO-6 drive or an LTO-7 or 8.
On the other hand if I buy an LTO-3 drive now then when it dies I have not lost that money, and can buy an LTO-5 drive to replace it (again saying money over a 7/8).
It's a moot point anyway as it assumes the drive will break, and secondly because I have decided to go RDX (which seems like a much better system than tape if you are using <10 tapes anyway).
Managed to get a great deal on a drive and cartridge bundle, rock on :D
Be interesting to see how you get on - after seeing them in this thread I am now considering getting a USB3.0 RDX drive and a disk to try out.
I see they also do some network versions (iSCSI I think?), any ideas how these work?
