This, having also used both for some time now.
Look up Async Shader support in Ashes of the Singularity and then decide which card will be better in the long run. With DX12 more games will start using this feature soon.
Yeah, you and i are a couple of the few who can cut through all the crap.
Yup look that up and then see what version of windows your using as well, if it isn't windows 10, remember to use the directX11 numbers for both AMD and NVidia.![]()
Is your 7950 voltage locked ? overclocking it to 1100 + mhz and memory 1575 will give you a 7970 pretty much which isn't leagues behind a 970 10-40 fps depending on game and res.
isnt leagues its twice as slow![]()
yes as you can see it's not double like how you do the non 1ghz 7970 vs a ftw 970 as well lol
all 7950 will do 1ghz with ease
