How's the build quality?
So how does the OPT work with Android upgrades? Do they push them out or does it lag behind like most non Nexus phones? Is there developer support from people like xda?
So how does one go about getting an invite?
have you considered RMAing it based on that? or you won't bother?Just an update on my current experience with the phone.
Grounding issue with the home button. I have now noticed it, this only happens when I'm holding it with my left hand, and use the right hand's pointing finger to tap it. Using my right thumb however is still fine.
not sure what to do when mine arrives as this is HW related, so no SW update will cure it.
Just got my invite and placed an order for the OPT.
Not sure how I feel about this, can't really justify upgrading from my OPO...
Edit: Just cancelled my order. Definitely an impulse buy after a 12 hour shift
Why did you add yourself to the reservation list if you weren't sure about upgrading?
Just received an invite out of the blue, which seems a bit odd. Perhaps they have more stock than anticipated?
I'd only be buying one to flog though, so seems a bit pointless.
to be fair, if Nexus 5X and 6X are priced competitively, OP better do something about the crappy invite system, or I can't see people favoring OPT vs say 6X if similar HW is used.
Are the China ones UK spec?
they dont have stock at the moment, people are saying 2-3 weeks delivery.
the time of buying to sell has now passed as they can be picked from China for not much more than through the invite.
Seems odd then that they're sending out invites unnecessarily :/
