- 19 Feb 2007
- Northampton
Would be nice
Any word on a fix for the blackscreen on bootup that happenes with windows 10 where it takes about 30 seconds to get to the login screen and your stuck with a blackscreen with the mouse curser. It was mentioned earlier AMD know about this so would be nice to know if theres a fix coming anytime soon.
So 15.9 beta release later, to celebrate the Powercolor Nano launch?![]()
Control Center>Video>Global Video Quality>Enable AMD Video Quality features in supported video player applications?
Check CCC Information tab > Software tab. Windows 10 may have downloaded and overwritten the Driver with the old driver that had this issue.
Matt i don't suppose you have any news from Asus and when we can expect Voltage to be unlocked?
Matt I dont think it would be completely unreasonable to expect Fury X in Crossfire configuration to be able to run BF4 Multi-player online 1440P at a constant 144 FPS (ultra preset with only MSAA at 0x / off)
I seem to feel the hardware should run the game faster than it does I get frames dropping here and there and it seems to ruin the experience for me.
I cant help but be extremely fussy!! I know for 90% of people or more this would be more than acceptable or just fine
I cant help but want that little bit more, its just human nature right? I'm using RP to force full-3d clock states... how can I get more out of this configuration?
I'm using mantle over directx and its obviously much more effective....
I just wish this title would run smoother! is it server-side performance caking?! what causes the horrible slowdowns!?
Dice have not added any performance any optimisations for the Fury X on the Mantle API in Battlefield 4, i would recommend using DirectX 11. The DirectX 11 CrossFire profile in Battlefield 4 works very well with 2x Fury X for me.
Would you use directx11 for290x crossfire?
Using 15.8 Beta Matt which I presume has the black screen fix in?
Still getting it everytime I bootup though when I restart the pc. Doesn't happen when I bootup from shutdown only when I do a restart.
Its not the end of the world but when your in a rush its a little frustrating to sit there 30 seconds waiting for the login screen to show up especially when your on a SSD drive and it normally takes a few seconds.
