No offence to Ferrari but that score is very very low and puts it in line with a GTX 970 with a small overclock![]()
It's in a pants rig, what do you expect? Pardon the pun but he's built a Ferrari with a Cortina engine in it.
I've seen a Radeon 290 score 3000 points more in Firestrike going from a FX6300 to a 4770k.
CPU makes a massive difference to all of the scores.
That's slower than my 970 and stock i5 3470!
http://www.3dmark.com/3dm/8524334
+1
It's a strange choice of Cpu to power such an expensive card. If i was him it would be coming out asap.
Actually its wrong. It had a frtc 60fps cap
The actual result with frtc off is 10400+
This will beat most 970s [snip]
...except oc which will increase the fan noise considerably on the 970.
How is it strange?
I have had that CPU a while.
I am unsure whether to upgrade it yet as its suitable.
It's supposed to be up there with the 980s, not the 970s.
entirely dependent on the cooler of course. wrong thread for discussing 970 noise though!
Anyway, give us a link then![]()
Whoever brought up the 970 in this thread should realise for the same performance you will have to crank the oc massively thus making it much noisier. Defeats the object of wanting a quiet machine. I will post update later as I'm at work. I'm sure it would hover at 11000+ with an i7 in it but I have not made up my mind whether to buy one yet or not.
CPU upgrades are a funny thing. Right now you may need more but moving forward you will be fine once DX12 games are common. If your gaming experience is fine you don't need an upgrade to push some arbitrary 3D synthetic benchmark numbers. If you have a 60hz monitor and you're getting 60fps in most things, to me that doesn't justify an upgrade. If you live to upgrade and benchmark by all means blow some cash on an upgrade.
Guys. I bought a PowerColor Nano and recieved it Monday.
Just doe 3D Market score when 10% catalyst overclock.
Not bad eh.
Small amount of coil whine at times but not as bad as a 290 when that gets going.
Bear in Mind the not sooo fast Intel i5 - 4460 doing the CPU work.
Lian Li PC-Q33WB Mini-ITX Cube - Black Window:
https://www.overclockers.co.uk/showproduct.php?prodid=ca-706-ll
amd powercolor nano
16gb fury ram 2400
intel 15 4460 cpu
asrock z97m-itz/ac
650 corsair modular psu
500gb samsung pro 840 ssd
I am not spending cash unneccassarily.
I have done a search and the combined scores for the AMD FX-9590 are all below 4K, GFX and Physics are fine....
If I had a faster CPU and frtc off the nano would win for sure.
Combining Graphics and physics scores results in lower scores if its an AMD CPU even if the performance is higher on both things its combining.
Clearly they are using a different equation to calculate the end performance depending on what brand of hardware you are using, its an equation that favours one brand over the other.
As the only owner of a Nano that horse has all ready bolted, you have effectively paid £10 per 1% of preformance increase over a 970 mini.![]()
