Yes it does, but its only Dx10 and above.![]()
Anyone know if freesync, crossfire and eyefinity all work together?
Freesync works with Crossfire but sadly not with Eyefinity, at least not yet.
didn't know this, any reason given why it doesn't work with DX9 titles? Or any indication from AMD if this will be sorted in the future?
Seems to be an issue with other AMD features too, The fps limiter only works on DX10 or above. If I run a dx9 game like SOC or some of the RE titles the 95 limit I've imposed (I only have a 75hz monitor) will not work, I know this because if I listen carefully I can hear coil whine when in the main menu. It's rare that it happens and even with the case at head height and only a foot or two away the whine is easy to miss but it is there if you listen out for it which told me the limiter wasn't working with those games.
Anyway back to the topic at hand, Maybe it's something in GCN causing these features to only work on DX10 and over.
Tbh if you running a GPU that can do Freesync then dx9 games one GPU is more than enough.
So a single 290 is enough to drive any potential eyefinity freesync setup, like 3x4k or 3x1440? I think we both know its not.
I think Guild Wars 2 is only DX9 too and with 2 x Fury Xs I can struggle to hold 144fps in the busy community hub places (Lion's Arch, etc.).
I believe the game is CPU limited, but I'd have thought Freesync would still be able to help? Unless it only helps with GPU limited situations?
So they should just be ignored for not being part of the majority?
Back to my early question do amd plan on sorting this in the future?
FreeSync and Gsync isn't magic. It isn't going to boost your Frame rate from 60 to 144fps.
You get what ever your system can output Freesync will just help smooth out frame rate and remove screen tear. Though you running Xfire and that is a DX9 title and from AMD freesync shouldn't be working. DX10 +
Above when I say.. YES I am talking about mainstream Single Display and Mainstream Frame rate targets what is still 60fps.
People who want multi-displays and high frame rates are not the Mainstream target.
Just let me get on the telephone and find out for you! * Ring Ring...Ring Ring...*
(2 minuites later)
No answer mate, couldn't tell ya! Only AMD knows! Didn't realise you was so interested in freesync pgi? You wanting to go AMD?
(could get three for £900, that's not bad at all! Paid £700 for my swift!).
