Anyone got any opinions on the £1 eliquid range? Since getting the subtank mini I'm going through silly amounts of juice so could do with a cheap juice as its getting to be very expensive
You got a link?
Bugger it, if USB charging wakes up its a bonus if not, then I'm not really bothered.
I think I know the one you mean, two holes bored through the top for the batteries, think he showed it with a small Lipo pack as well.
You mentioned you had bought one of the mamu faceplates, I might be able to get some cheap face plates printed through a member on a local vape group, will see how much he can print them for and if its cheap enough get a batch of 5-10 done. Shapeways are horrific on postage
So how do I know when I need to replace a coil? Its been a week now, I've been told they should last a week but I'm not really noticing anything different?
I have the following tank:
http://www.vapeclub.co.uk/clearomiser-tanks/aspire-nautilus-mini-bvc-tank-clearomizer.html
Is there a limit to the wattage I can use on this tank? I'm running it at 4v and 15w but feel I need more of a hit! I'm using the Cool Fire IV battery mod.
Snip
Found my Cthuhlu v2 sitting on my desk when I got to the office.
First impressions are not good. Shoddy machining everywhere and the threads are as rough as a badger.
The outside of the tank looks well made it's the inside that concerns me. There is a little ring that you are supposed to tuck your wicks under when building. You only get one for the two decks and try as I might I can't get the damn thing to go on to the dual coil deck. The threads are cut so badly that it just snarls up and won't budge.
I will try and persuade it later with some tools it doesn't bode well. Once on, I doubt it will come off again if I want to use the single coil deck.
I kinda skipped the EGO style pen vape and went straight in with this, so it's effectively my starter kit. Am looking around at bigger devices.Sorry i did not mean that in a bad way.. but compared to a Yihi or DNA based chip, the isticks are cheap about at 6 - 8 watts on the 20w model i would not expect coil whine even on an istick..
Yeah, Coil Whine was the closest description I could come up with.The whine you're referring to is the circuit working as intended, similarly to PWM, it switches the power supplied from the battery on/off repeatedly to give the power required, you'll notice the 'whine' changes as you vary the watts and disappears at max.
Send it back, threads on mine are very well machined, didn't even require a break in period. I also got two wick rings, one pre fitted to each deck. Sounds like you got a shoddy unit.
I found when wicking, don't force cotton down the wells, have it near enough resting on the bottom of the build deck and gently nudge a little down.
One more con I've noticed...the 510 pin is very short, I had to wind it out almost 1/4" for it to make contact on a few mods, provided I remember a screwdriver I'll try the dual coil deck tonight.
It sounds more like the pulsing/buzzing from electricity arcing, albeit on a tiny scale.
So how is it that my Curve will go up to 20w (18.9w on 1.6Ω), and yet every liquid I've tried tastes burnt if I go much above 10w?
What do I need to make this thing billow out a bit more?
Arrived today and ordered Friday night so that is excellent service. Couldn't resist opening it before taking some pics. Will inspect and build it in the evening.
http://imgur.com/a/39TwS
