**** The Official Google Nexus 6P Thread ****
25 Jun 2007
Downtown
Quick specs:
- 5.7-inch Quad HD display OLED
- Metal Body
- Snapdragon 810 SoC, 3GB RAM
- USB-C + Fast charging
- Stereo FF Speakers
- Fingerprint sensor
- 32/64/128GB Storage
- Android 6.0 Marshmallow
- 159.3 x 77.8 x 7.3 mm
UPDATE
- 3450mAh battery
- 178g
- £449/499/549
Announcement on the 29th September.
OFFICIAL SPECIFICATION
Operating System
Display
5.7 inches
WQHD (2560 x 1440) AMOLED display at 518 ppi
16:9 aspect ratio
Corning® Gorilla® Glass 4
Fingerprint and smudge-resistant oleophobic coating
Rear Camera
12.3 MP¹
1.55 µm pixels
f/2.0 aperture
IR Laser assisted autofocus
4K (30 fps) video capture
Broad-spectrum CRI-90 dual flash
Front Camera
8MP camera
1.4 µm pixels
f/2.4 aperture
HD video capture (30 fps)
Processors
Qualcomm® Snapdragon™ 810 v2.1, 2.0 GHz Octa-core 64-bit
Adreno 430 GPU
Memory & Storage²
RAM: 3 GB LPDDR4
Internal storage: 32 GB, 64 GB, or 128 GB
Dimensions³
159.3 X 77.8 X 7.3 mm
Weight
178 g
Color
Aluminium
Graphite
Frost
Media
Dual front-facing stereo speakers
3 microphones (2 front, 1 rear) with noise cancellation
Battery⁴
3,450 mAh battery
Fast charging: up to 7 hours of use from only 10 minutes of charging
Wireless & Location
LTE cat. 6
Wi-Fi 802.11a/b/g/n/ac 2x2 MIMO, dual-band (2.4 GHz, 5.0 GHz)
Bluetooth 4.2
NFC
GPS, GLONASS
Digital compass
Wi-Fi use requires 802.11a/b/g/n/ac access point (router). Syncing services, such as backup, require a Google Account.
Network
GSM/EDGE: 850/900/1800/1900MHz
UMTS/WCDMA: B1/2/4/5/6/8/9/19
TD-SCDMA: 34/39
CDMA: BC0/1
LTE (FDD): B1/2/3/4/5/7/8/9/17/19/20/28
LTE (TDD): B38/B39/40/41
CA DL: B1-B5, B1-B8, B1-B19, B3-B3, B3-B5, B3-B7, B3-B8, B3-B19, B3-B20, B3-B28, B5-B7, B7-B7, B7-B20, B7-B28, B39-B39, B40-B40, B41-B41
Phone is carrier-unlocked with wide range band support for service providers worldwide. Check with your service provider for more information.
Sensors
Fingerprint sensor
Accelerometer
Gyroscope
Barometer
Proximity sensor
Ambient light sensor
Hall sensor
Android Sensor Hub
Ports
Single USB Type-C
Single Nano SIM slot
3.5 mm audio jack
Material
Anodized aluminum
Other
RGB LED notification light
Based on all the leaked pictures of this, ill be buying the black model. White looks terrible with that black bar at the top.
As per the nexus 6. It is just too big for me. Don't want a phablet. The new nexus 5 will be just about as big as I want. It'll be interesting to see the performance contrast between this and the new N5.
nexus 6p, a phone with so much bezel it has some on the back
other than the processor, camera and fingerprint sensor, i wonder how it stacks up against the nexus 6. obviously the processor and camera are going to get a bump in spec and the finger print sensor was meant to be on the nexus 6 until apple purchased the company
is the aluminium build and camera hump better than the oversized moto shape and build
the handset seems narrower but the height seems to match the nexus 6
Here are the colour options. Because of the black bar at the back black seems like the only decent looking option to me.
Oddly.. I happen to like the black bar. I certainly don't dislike it.
It's different. And different is good. Perhaps it'll help with better signal.
