** LG 34" 3440x1440 IPS CURVED, NEARLY HALF IN PRICE!! **
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
October last year we launched the amazing LG 34UC97, I am still using mine right now, absolutely gorgeous monitor. We sold nearly 1000 of these stunning screens last year and they were also practically £1000 each. :eek:
Today we launch the exact same monitor but without Thunderbolt connectivity, the result is compared to last years launch price of £989.99 we are able to offer the none Thunderbolt version at just £659.99, the screen is identical in every way and at this price is a great deal for such a stunning display.
LG 34UC97C 34" 3440x1440 IPS WideScreen Super-Wide Curved LED Monitor @ £659.99 inc VAT
21:9 Curved UltraWide QHD (3440*1440) display offers visual comfort with 2.4 times more visual information at one time than a Full HD monitor. And also, the QHD resolution’s 1440p vertical height allows you to use more vertically than a 29 inch 21:9 monitor.
IPS’s 178’ wide viewing angles, close to 180’, allow you to view the screen clearly without distortion. Also, the Curved IPS provides an immersive viewing angle covering the entire viewing angle around your range of vision.
You are guaranteed an immersive artwork by perceiving the same color as a subject on display or print through a sRGB over 99% colourspace and IPS’s accurate colour expression.
Using MaxxAudio® technology you will experience deeper bass and crystal clear highs. Equipped with two 7w internal speakers and MaxxAudio® technology, the 34UC97 provides cinema surround- like sound, allowing you to enjoy movies without any extra external speaker or sound output equipment.
Specification:-
- Screen Size Class (diagonal): 34" Curved
- Panel Type: IPS
- Aspect Ratio: 21:9
- Resolution: 3440x1440
- Color Gamut (CIE1931): sRGB 99%
- Brightness (typical): 300 cd/m2
- Contrast Ratio(Original): 1000:1
- Response Time: 5ms
- Viewing Angle (CR>10): 178/178
- Colour Depth (Num of Colours): 1.07B (8-Bit+FRC)
- Pixel Pitch (mm): 0.2325
- Surface Treatment: Anti-Glare 3H
- Curve: 3800R
- Connectivity: 2x HDMI, 1x DisplayPort
- Speakers: 2x 5W
- Tilt: -5 / +15
- Set with stand: 830.5 x 224.5 x 472.9
- Set without stand: 830.5 x 106.4 x 370.3
- Weight: 8.2kg
- Linus Review:
- Warranty: 2yr (LG - 0344 847 5454)
Only £659.99 inc VAT.
ORDER NOW
LG 34UC97-S 34" 3440x1440 IPS WideScreen Super-Wide Curved LED Monitor @ £749.99 inc VAT
34UC97 provides two Thunderbolt2 ™ ports to directly connect a Mac PC and Pegasus2 storage directly to transmit data more than four times faster, than a USB 3.0. As a result, there is no concern of slow transmission from using a USB or HDMI connection. You can connect to various devices with the two HDMI and two USB 3.0 ports, and a Display Port. And, If you have a Mac, you can connect directly to the 34UC97 via Thunderbolt 2™, which transmits data more than four times faster than USB 3.0.
Specification:-
- Panel Type: IPS
- Curve: 3800R
- Connectivity: 2x HDMI, 1x DisplayPort & 2x ThunderBolt
- Speakers: 2x 5W
- Tilt: -5 / +15
- Weight: 8.2kg
- Linus Review:
Was [£799.99] Inc. VAT
Only £749.99 inc VAT.
ORDER NOW
We expect our stock to land early next week. :)
VIEW OUR FULL RANGE OF CURVED MONITORS!!
I must be mad but I'm really tempted by a LG 34UC97C 34" ;)
I don't really play many fast paced games and I 'd love this resolution for productivity.
If only I could get OcUK to open me one up and send me one with zero dead pixels and no backlight bleed??? <pretty please with bells on>
Why I've got one for my work PC. :)
I very much doubt you will get a 34" Ultrawide with no BLB, at least the IPS models. They all use the same LG panel underneath and it's prone to bleeding.
I don't mind IPS glow but lots of BLB would put me right off, I have 3 x Dell UltraSharp 2407WFP the oldest of which must be 8 years old and it has none of them have that much BLB to speak of!
I know i am Biased, but these are truely beautiful screens, both in the way they work and the way they look - either for work or gaming
@Joe! - as we have been discussing in the LG Feedback thread, the issue with BLB from the LG factory has been addressed at a factory level, and for a while now models with an upgraded build have been coming into the UK - we havent had a complaint yet so i hope this eases fears over BLB on LG IPS panels
@ TheMorningStar - honestly, not really - you may still get some dont get me wrong, but with the introduction of things like IPS it does tend to decrease the chances. if you must have 0 dead pixels go for a monitor that is Diacom (i think thats how its spelt) ready - basically medical grade so guarenteed no dead pixels - expensive but peace of mind
@EmmaNeil - you are not wrong :)
Tempting, I can see how these would be great for work. But do they make good gaming monitors? Is a single 980ti enough to drive one at a decent frame rate?
I don't own any of the LG models so I haven't been monitoring that thread, but my apologies and thanks for the information.
How new of a monitor has no BLB? And how can I be sure to get one of these models? I picked up my Dell around 2 months ago, produced in March 2015 with revision A01 for instance.
As Legend has said, the most you're going to get is 60 FPS. My 980Ti (G1 Gaming) at its clock speeds does just well enough to maintain 40+ on GTA:V with absolute max settings and 2x MSAA, it did an entire playthrough of Tomb Raider without dropping below 60 FPS on absolute max settings, and it manages Dirt Rally, Assetto Corsa and F1 2014/2015 just fine.
I'd say you are not going to suffer if at all.
So it's fixed on all of ultra wides then? How did LG manage that when it's been an issue up till now, not only for LG but for every manufacturer using LG UW panels in every size up to this point?
Since I guess he's from LG I would expect him to be talking about the LG branded monitors only. Not for every manufacturer using an LG panel in their monitors however. :)
No, i mean is it fixed for all LG models.
Daniel - LG said:
@Joe! - as we have been discussing in the LG Feedback thread, the issue with BLB from the LG factory has been addressed at a factory level, and for a while now models* with an upgraded build have been coming into the UK - we havent had a complaint yet so i hope this eases fears over BLB on LG IPS panels
plural.
The point was nobody else has managed to sort it the issue with existing panels, even dell, so i'm skeptical LG has unless they've changed something in the manufacturing process of the panels themselves. In any case, he says LG have fixed it so does that apply to the 34" curved monitors only or is it every UW going forwards? I'm just asking for clarification :)
Define decent? The most you will ever get from a 60Hz monitor is 60FPS.
You've answered your own question there. Mine, albeit not worded very well, was about whether a single 980ti is enough to drive it. And judging by Joe's reply I'd say it probably is. But I'm stuck choosing between going super-wide, or 144hz IPS. 1st world problems.
