Permabanned
 - 12 Sep 2013
 - Knowhere
This was posted on the forum some time ago by AMDMatt if I remember right. there certainly does seem to be a lack of options for some.
1920 X 1080 @ 120Hz will only open up two VSR modes:
1920 X 1200 @ 120Hz
2048 X 1536 @ 120Hz
On Nvidia you can choose right up to 3840x2160 @ 120hz
I don't understand why there is a limit I'm running a 60hz 1920x1080 monitor that registers as 75hz.
And yea the 55-90 fps limit for frame limit is downright stupid. What VSR mode exactly do you use then? Also this is what they include on the webpage for FRTC.
They only support 60hz and 75hz lol!!
I'm not sure why vsr mode would have a limit on fps at 4k with a 120/144hz screen but not a 60 hz, I tested 4k like you mentioned and both Steam and Fraps show the fps as being beyond 250 to 300 a lot of the time. I suppose because what they're showing is not what's being put out there may be a physical limit to what you actually get but you'll need someone with a 120+ hz 1080p monitor and a better way to read the fps to know for sure.
EDIT: When I actually think about it a bit more how I'm testing doesn't determine anything.
