@Borsch, you gotta link to that combine?
Sorry, just got that pic from facebook AC mods page
Odd that other tracks don't work either.
yeah, I particularly love the coathanger for aerial![]()
Sweet, looks like I'll have to pick this up.
How easy is it to create you're own car?
To build the actual car model is a lot of time and work. Starting from base CAD design following images or in some case blueprints/dimensional drawings.....believe that's the case anyways, take a look at the ac forums car model section. Really impressive to watch some very talented people at work
I stuck to making liveries instead![]()
What's your setup?
Could be something to do with AC now using multiple threads for physics, as I don't think much else has changed.
Intel i5 4690K, 8GB RAM, GTX 980TI.
Try reducing your force feedback rate from the new setting of 350Hz back to 333Hz (which it was in 1.2) in \system\cfg\assetto_corsa.ini
[FORCE_FEEDBACK]
MAX_FF_RATE_HZ=333
You might try knocking it all the way down to 60 just to rule out that option.
