What can you do with Python?
Caporegime
24 Oct 2012
Yer nan's knickers
As title really, loads of people recommend Python as a starting language, but what could you theoretically code with it? My nephew's looking to code, just trying to get some inspiration for him really.
I am not a Python developer however I am fairly confident in saying anything you could do in another language is achievable in Python.
How old is your nephew and does he have any prominent hobbies/interests? Working in the domain of something you enjoy is the best way to get inspired/stay motivated.
Code academy is an excellent tool for new or experienced programmers alike; https://www.codecademy.com/tracks/python
As far as which language to learn, it doesn't matter a huge amount when you start out, it's more important to get a "feel" for programming. Learning a new language isn't too difficult once you have experience with programming in general.
As a Python developer my answer is: anything
If he wants to write iOS/Android apps then don't choose Python. Otherwise it's a great language.
How old is he? Might be better to start him programming with Scratch, then move to Python. There's free resources for it and I've recently spotted a Scratch - make a game magazine in Sainsbury's
You can write android and IOS apps in Python using packages such as Kivy.
Python is Turing complete so anything that is computable, see Gödel's incompleteness theorems, turing halting problem and Church's unsolvable Number theory for some limitions.
In practical terms, python is a great scripting language and a nice alternative to bash for getting things done quickly and legibly. But don't put it in anything production related, simple things like upgrading the OS can kill python projects since the versions are so incompatible.
Python's integration with C is pretty tedious (excepting the cython project, which is roughly python), but that's unlikely to upset a beginner too much. If your nephew has any interest in maths or the sciences, solving problems with code instead of paper and a calculator is pretty good. If he's more interested in visual stuff, I'd suggest writing a game.
Struggling to parse this. What's the relationship between the OS and the Python version? A depressing amount of code still requires 2.7, since no-one is willing to spend the time porting it to 3.x, but that doesn't correlate with the operating system.
On the other hand, python's approach to typing and runtime performance might kill enterprise-style production code.
Well, ajy not always be upgrading OS but installing on different OSes for sure. We have had python script that work fine on some of our systems but then completely fail on other because depending on what OS you are using you will either get Python 2.6, 2.7 or 3.2+
the performance of course is another reason, the latency itself would make it useless for our products and we would have to spend thousands and thousand per month on additional CPU costs.
Again, it's a case of simply using the correct version, however if the program is converted to an .exe for windows it should carry it's own version and have no issues.
What are your products?
Thanks for the input all!
He's 11, reminds me a lot of when I was a kid except that in my days it was MS DOS and Qbasic. I remember going over to TurboPascal7 and was amazed!
He loves computers and is always messing about with projects. I bought him a Pi last year and he's made a media server out of it, really clever little man.
If he's got the Pi then I would have thought Python would be the programming language of choice.
However, if he also likes tinkering with PC's than maybe something like Visual Basic .Net maybe worth looking at. Could be useful for him to have a play about with the Forms and drawing buttons etc...
Just to throw my 2 cents in here... (as a Python developer)
Used with Qt and some Python libraries (such as PyQt) you can build entire cross-platform desktop applications.
Its used a scripting language for Autodesk tools (3DS Max and Maya), you can make plugins for these.
Its great a general-purpose scripting language, with very powerful libraries. I've written scripts to dynamically generate images based on data input. Usable on the Pi quite easily too.
Its great for learning the basics of programming in an easy-to-understand way. That said, I'd always advise branching out once you've got one language under your belt - JavaScript and C# are pretty standard these days.
As a final aside, its on the new GCSE's computing courses as standard, so its worth picking up as it'll come useful at that stage (assuming he's not at GCSE-age yet).
