Oh you mean Mantle?![]()
Side note, Matt could you ask(Bang heads
Side note, Matt could you ask(Bang heads) about freesync support in the Linux driver (If/when.) please.
I have been waiting for the Sapphire Fury X to be in stock for the past month or so since my last was RMA. I have noticed that MSI and Powercolor are now in stock? Do any of you have them? Have you had any trouble with them? What are the differences between them manufacturers? I don`t know if I should wait longer or ask ocuk to send on one of those in stock??
Dunno but it says DUE SOON for at least a month now without any updates. Why did you say Powercolor over MSI? I am a bit anxious as the last one had pixel corruptions from Sapphire and never bought any other AMD than Sapphire![]()
Right OK, how about the cooler - are they the same or are there differences?
I see the XFX version became available this morning as well.
Why are there different prices on different manufacturers if the card is the same?
LoadsaMoney cause rest went for TI that can overclock. At this rate we will have next gen cards before we see core voltage adjustment. Was planing to buy one but with every week it makes less point as next gen cards out sooner and sooner. Not to mention 290x is doing the job not bad![]()
Can I upgrade to double TROH membership?
Unfortunately I bought this a day before the price dropped by £20. Oh well.
Going to build the system soon, just got a few things to sort out now.
