- 18 May 2010
- London
As an Amd user i can say most of this is tosh. There was a gap at the start of the year but that's the largest gap for years. It's usually one a month or more which it is now. Nvidia drivers have not been great this year either you only have to look in the driver thread to see this. As far as single cards go Amd are every bit as good as Nv atm. I will say that the software suite on the Nvidia side is superior but that's not drivers that's features that not everybody will use.
I am not going into Sli and Crossfire as that seems to switch around all the time as to who has it running better.
I for one have had zero trouble for the entire duration I have had my 970 (and my 670 before that).
The issue people are having in the Nvidia driver thread, is most likely because they are running their cards beyond spec. If you over clock your gpu, then you cant expect Nvidia to account and program for ever single possible permutation out there.
Which is why I said on that thread, before posting regrading issues, revert everything back to stock and then we will offer you help. Instability due to OC's can not be blamed on drivers!
It's not just me that says that Nvidia have better drivers here if you read the $300 to $400 paragraphe they say "But the GTX 970 overclocks like a champ and uses nearly half as much power as the energy-gobbling AMD card. You’d be happy with either card, to be frank, but you’ll have to decide which trade-off works better for you: The GTX 970’s efficiency and Nvidia’s superior drivers/software, or the Radeon’s slightly better performance and vastly more memory, which comes with vastly higher power consumption. "
