Asus Strix 980 Ti - fan noise question.
Status
Not open for further replies.
Permabanned
17 Jan 2015
HI. I have a question about my graphic card fan noise. I dont know what to do now.
My fans are rattling ( very small rattle i must put my ear close to card ) for few seconds randomly from time to time, while changing RPM to faster or slower.
I dont know what to do now. Is this reason to RMA?
Card is Asus Strix 980 Ti. I will be very greatful for help. I know this is my next topic, but now i explain my problem more clear.
If you are being serious, I had a similar issue on my Strix at 40-60% fan speeds, but at nothing else. I fixed it by screwing in the 4 screws as far in as they would go under the fan that was making the noise, which was the one closest to the PCI-e cover in my case.
Keep your ear away from the card and your problem is sorted,, just enjoy your card and play games for a bit
If it gets worse then worry about it
Plz plz stop trolling u asked yesterday about it.
If u want ny honest opionion sell your entire pc and go and by an xbox. I
In your situation that was random rattling? I mean it will rattles sometimes or always?
In my card it is just random issue. Sometimes rattle, sometimes not.
It always rattled at 40-60% fan speed, I thought it was something to do with Afterburner's polling - since it only occurred with Afterburner open, but after I stopped the problematic fan with my finger and the noise went, I figured it was the fan and subsequently my custom fan curve that was causing the noise. Mine was audible when sat ~1.5m away from my case, with the side panel closed, as well as with headphones on.
Just try screwing it back in :p
This is your 5th -6th thread about noise from this card.
If you are that worried about it then send it back where you bought it from.
Its very weird. Its totally random. And its hard to reproduce. Maybe 1 of 5 tries. I can hear a very small rattle noise ( for 5-6 seconds ) coming from card when the card fans are starting spinning up. ( and i must put my ear close to card ).
Also my case is open and its sitting near by me. What do you think guys about this?
My pc is on desk. Case is on desk, just near by me ( maybe 20 cm ). So i have good hear.:)
Also my case is opened. So i am just sitting near my graphic card. And from time to time i can hear slightly little rattle from card. Is this something to worry about?
Maybe you have a rattle snake inside the case?:o
put the side back on then?
Yes i can put side back on. But i want to be sure that i can rma card because of this problem or not necessary?
No u cant. Fans make noise when they start stop and go faster.
Any other reason u can think of and want to start a new thread about no u cant rma it. Unless it actualy fails no u cant rma it.
I cannot believe this guy is still here. the mods seem to love him, ive reported all his recent posts and pointless threads and still they continue
it must be one of the mods/dons trolling us
Status
