This is a very popular cooler, but for me at the moment my motivation to use it is almost zero.
Got my new rig this week, found out PSU was dud so replacement today along with cooler.
Installing it, there was an issue with a bolt/nut... the nut just kept tightening so definitely manufacturing issue with tolerance. Tried a different nut/bolt combination and seemed to work, tightened them up maybe cautiously.
Fitting the cooler and bracket, tightening 2 of the bolts kept just turning in the motherboard. I don't have access to my backplate, so thought i'd give it a go. PC ran fine, 42c idle, and 71c max load (thought this was a bit much). Because I had the pc apart, thought lets go back and do job properly, tighten the bolts etc...
Worst mistake ever. The whole set of bolts must have been toasted, cause 2 of the screws now won't come out of the risers, which means RMA job.
Anyone else experienced things like this with the cooler? Or just terribly bad luck on my part?
