- 22 Jul 2012
- London
10 years ago, maybe
Nice colour though.
Nice colour though.
If it makes any difference, when I run 4K DSR with the G10+H75 setup on the MSI 6G and set GPU-Z to show the "Max" temperature I can get up to 57c. Still a 20c drop on the 79 odd that the default Twin Frozr cooler got up to so I'm happy.
You'd get better Temps with a 750d and the rad mounted behind the front 140 intake. Ditch that case that looks to be a hand me down from moses and come into the modern era.![]()
Good case thats why low temps @ idleThough I have never seen my idle in the 20s, maybe AWPC has a cold room?![]()
Your right about temps they do rise a bit after an hour or so especially with a slightly lower CFM fan (300RPM less than the Corsair model).Sounds good. A lot better temps than before. Shows you how good water can be. Both my cards max out at under 40c after hours of 99% stressing at 1480mhz 1.255v.
Id let the 4k run for a good while to make sure there no issues with it as the water heats up over time until it reaches its equilibrium. Where it stays at a pretty much constant temperature. Will let you know how well everythings performing, rad, fans airflow etc.
Really? I thought these cards were overclocking beasts? With those temps I would be tempted to see what is the most I can get out of it myself
4K is lovely though isn't it?
Have you ever had 144Hz or g-sync etc? How do you find it compares to 4k at 60Hz?
Hey guys - moving a little away from the watercooling side.. is anyone having any issues with GTA 5 at 3440x1440? I get random dips from 60 to 45 fps on a G1 980 ti. Sometimes to 30. It's making me crazy. Driver issues?
Hm..
I just got an asus strix 980ti, why is my base clock saying 1000mhz?
How do I change the mode to get it at the proper base clock?
If think there's a lot of good stuff around, I can't stand the stock one over 50%.H55 stock Corsair fan seems to be best for temps it runs @ 1600rpm but is not quiet at all
Am finding temps on the GPU rising to 60C with other lower CFM fans![]()
What do you mean by proper base clock? For every load there is a different clock.Hm..
Was trying this one:If think there's a lot of good stuff around, I can't stand the stock one over 50%.
Which one are you using?
I'll try this on Monday.
Picked up a couple of 980ti's today so will be fun seeing how they do over the coming weeks. Just going to paint the green bits red to match the rest of the system.
http://i1280.photobucket.com/albums/a497/SegaMegaDave/Random/Gaming%20PC.jpg[/G]
