Both will fit into my case but which one will be better in terms of cooling?III is a three slot job with individual heatsinks, IV takes up four slots as it has a massive back plate that sits on top instead of the individual heatsinks.
Thanks for all your help! Will report back the before and after results when I've installed this cooler
EDIT: Would a OCZ 550W PSU be able to handle the R9 290X with AC Xtreme III cooler, 3570K CPU, 6 Case Fans and 2 HDD?
Would a 600-650W PSU be sufficient enough (Bronze or Gold rated?) as I want to overclock the card in 1-2 months time to the max and my 3570K is clocked to 4.2GHz as wellIt has 38A on the 12V. Thats cutting it pretty close. The card can spike to 350+w and the CPU i think has a tdp of 77w. When you chuck in things like the motherboard and such then you are walking a fine line if not crossing it completely.
It will probably boot up and run fine until you have the card get toasty under load and a spike could trigger the protection the PSU.
