Under the rules drawn up by the*Electorate Commission, if you apply for anonymous registration and are rejected then NO ENTRY OF ANY KIND will be made on the register. In other words, it’s possible to return*an anonymous registration form and still have your name and address blocked from appearing on the register, even if the*the application is*rejected.
If the anonymous registration application is rejected, no entry can be made on the register for that elector either as an anonymous or ordinary elector, not even based on any original canvass form or rolling registration application. If the anonymous application is accepted, the original canvass form is disregarded for that elector and only the anonymous entry shall apply. This does not affect any other people on a canvass form; they should be registered normally unless they also apply for anonymous registration.The application must contain the elector’s reason as to why they are applying for an anonymous entry. The application must also be accompanied by either a court order or an attestation.
Electoral Commission Guidelines Part F. Anonymous Registration 6.19
What this means is that you will not be entered onto either the electoral register or the record of anonymous entries. Your voter’s registration form will not be processed*and you will be effectively exempted from appearing on the register. Your details will not be held on any separate register and*your name and address will not show on either the full or open register. Nor will it be shared without any outside organisations, such as credit reference agencies, bailiffs and debt collectors.
For all intent and purposes it will be as if you no longer live at your current address. And it’s all perfectly legal!
The downside however is that you will no longer be eligible to vote. But for those who are hounded by persistent abusers of the information held within the electoral register, that will probably be a small but*merciful price to pay.
