The cooler itself without a doubt, but the fans on the G1 tend to get loud and the G10 installation is not as easy as with the 6G.Would you say the Gigabyte G1 is better than the 6G? Can you also go G10 on the G1?
Coil whine is also a tangible risk (mine had it).
Is the EVGA hydro cooler worth the extra money v G10 & H55?
You have a reference board right? EVGA is 90£, G10+H55 65£ but you would have to take care of heat spreaders for VRM and memory.
Having reference I would go EVGA, it looks much better.
The G10 ruined my case
(but idling at 2 degrees delta is pretty cool).
