Doesn't work on a h440 intakes are really bad due to sound dampening and small holes for the air to get in.
Have 1 unblocked 120mm exhaust at the back and the d14 pushes out the back just need more cool air inside the case.
Yeah, if you are getting heat build up inside the case you'd be better off having more fans on exhaust, air will alway find a way in to the case, getting hot air out is the priority
I personally avoid EVGA now, I think their coolers are utter crap compared to others.
Hows everyones 980ti been once water cooled?
just tested 79c still when gaming. made no difference putting the fans the other way
Ideally you want to keep the card running below 63c for optimal performance to prevent thermal throttling. This is easiest with water, with air loud - unless you are using a good after-market cooler (like the MSI 6g).
At 63/73/83c it drops the volts slightly to attempt to reduce the heat generation - so to avoid this voltage changes keeping the temps down is advised.
This is the thing i dont get, particularly with the aftermarket cooled cards. The 63c cut off point is a bit daft. With a custom fan setting sub 75c is pretty easy even though 75c is perfectly fine for a gpu.At 63/73/83c it drops the volts slightly to attempt to reduce the heat generation - so to avoid this voltage changes keeping the temps down is advised.
Not running at 4k are you?![]()
Uh-oh![]()
Yeah, got my two under water so didn't bother doing that when I flashed my bios.You can disable thermal throttling by spending one minute in the BIOS, the voltage drop can really mess up the overclock!
It's a relief to be on water and stay away from that 63 degrees threshold.
It's odd really, only makes sense for reference coolers. I guess it reduces the number of people who fry cards.This is the thing i dont get, particularly with the aftermarket cooled cards. The 63c cut off point is a bit daft. With a custom fan setting sub 75c is pretty easy even though 75c is perfectly fine for a gpu.
You think even the Hybrid EVGA is crap?
Have noticed the CPU AIO kicks out a lot less heat under load. Might be because a certain amount of heat is exhausted out the radiator, instead of left to build up in the case.
Cooling wise of course not. Noise wise, yes.
Even in idle the hum (or drone) of the crappy pump they used drove me made, I sold mine. If only they'd included a PWM controlled pump.
The HSF are marginal @ 4K IMO too much heat gets trapped under the backplate. Go AIO or full water is best. As per here my temps are great now on AIO but before were marginal or the card throttled. Your other option is buy a case you may not even want with about 6 x 120/140mm high CFM fans in it !Really debating putting a g10 & h55 onto my zotac.
Case temps get toasty when gaming due to case not having good airflow.
( has 3 x 2200rpm ek vardar intake at fron, 3 stock fans intake at top)
Gpu can get up to 80c quite quickly when gaming and cpu goes to mid 60's.
With the zotac dumping all the heat into the case its not going to be helping temps.
Pump noise is what always kept me from AIO coolers, luckily the H55 can run at lower rpms (at 100% the buzz is too much, 60% in idle is fine).
