**** The Official Google Nexus 6P Thread ****
For those who upgraded from a Nexus 5 how are they finding the 6P? How good is the battery life in comparison to it?
I'm getting used to the size. I find if I'm lying in bed trying to use it one handed it's very easy to drop, but when I'm up and about I'm having no issues. It is a slippery phone due to the size and (IMO) too thin sides, but it's not slippery in the sense that my old Galaxy S3 was, where the shiny plastic would mean it would frequently fall out of my pocket while driving.
While the Nexus 5 doesn't exude quality like the 6P does, I still prefer the grippy feel on the 5, which for me is the best-built phone I've ever seen, in terms of practicality. The optional rubberised back of the Moto X's help, but they don't extend to the side like the Nexus 5.
The battery life is OK. Better than the Nexus 5 of course, but I've not been blown away by it yet. In standby it is stupendous. I was still on 100% at 7 this morning having had it off charge since about 22:30 (wifi on, good network strength). Mileage will vary depending on signal though. With use it still feels too early to tell as it's hard to quantify, but I don't think I've not lost more than 50% in a day yet (I don't use wifi at work), but then I seldom play games or doing anything much stressful for a phone - mainly browsing and social media and a few videos, so my Nexus 5 always lasted a day too.* I don't use public transport (rural Northumberland) so I've no idea how it would stand up to an hours use on the tube or train or something.
Speakers are a big bonus and sound great for a smartphone - most laptops aren't half as good. They're quite 'full' and not lacking in volume. I could happily leave this on a bench or table playing music and it would do it fine. Obviously the fact that they're front-facing means you can be in the same room as someone and play videos or games and it won't annoy anyone else (as long as you're sensible or not hard of hearing), so no more cupping the horribly-placed speaker on the N5 in a vain attempt to try to direct sound in your direction.
I've not used the camera much beyond deliberately taking poorly-lit shots to see how good it is, and for stills it is very good, much better than I was expecting from some of the preview shots. I've not really tested the video quality yet, but as people say, the stability seems a bit off, but hopefully just a software fix. The front-facing camera is a bit poor, like any, but it would be perfectly good for selfies I suppose.
If I've got it in my pockets I'm finding the vibration annoying if my hand brushes up against the fingerprint sensor, but that's my only niggle. The only other very mild annoyance is that the reflection of light on the chamfered edges on the aluminium one catches my eye and makes me think I've got a notification. :p But that's it.
* If you're getting the constant wifi usage in the battery stats (same as most Marshmallow phones it seems - I had it on my Nexus 5), go to Settings > Location > drop down the menu and hit Scanning > turn off wifi scanning (and I turned off bluetooth too).
Fine, I should have said it's one of those things which, unless you find a problem by yourself, you should ignore
Well, yes... Isn't that rather stating the obvious? "If you don't have an issue with it, it's not an issue?". That's a little different to "you only notice it if you look for it" is all I'm saying. No?
You are right, btw. If you don't mind it, great.
The OnePlus cables are not specced for 3A, they are specced to 2A, as the OnePlus phone draws 2A. Naturally they're within spec for their own devices, not those adhering to actual standards for USB-PD.
Mine was delivered at 8:15 this morning. Unfortunately my lazy ass wife was still in bed so the postie gave it to the foreigners living up the street.
Last time something was given to them it took me 10 days to get it and the box was opened when I did!!
I'd love to know what the threshold is for fast charging as my OnePlus A-C cables charge my 6P "rapidly" according to the phone, which I wasn't expecting. Both plug into monitor-housed powered USB though.
You'd need to measure the current drawn with one of those sit-in-between dongles with a voltage and amp display to confirm. As one guy on reddit did a test using the Ampere app (software calculated results but still...) and found that whilst other cables reached up to 2.1A with the stock Google charger, only the Google one reached close to 3A at ~2.8A, resulting in faster rapid charging - The 2.1 still showed as charging rapidly of course, but it was a slower rapid charge.
I need to get a charging cable for when im at work, where are you guys getting spare chargers from?
I bought a spare from Google store. Yes £20 is insane but I now have all charging "issues" covered and couldn't be arsed with the uncertainty of what is type c compliant etc
I think the issue is just that the cable isn't identifying itself to the device correctly, had they used the right 56k ohm resistor any issues would be mitigated whilst still allowing the OnePlus to draw 2A (and other devices up to 2.4A) but the cable identifies itself as 3A capable as it uses the same resistor as a c - c cable.
That said I cant help feeling this is a storm in a teacup, I'm glad someone is drawing attention to the issue but presumably most 'decent' chargers will have over current protection?
