waterbolock query
7 Jan 2010
Up NORTH
Hi guys
Can anyone tell me the difference between the two types of vga block for my 980t i(VERY NEW TO THIS)
EK-FC Titan X - Acetal and EK-FC Titan X - Acetal+Nickel
The price is only around 10 euro difference
Cheers
performance is quite the same, the difference is the base.
EK-FC Titan X - Acetal - has copper base
EK-FC Titan X - Acetal+Nickel has nickel base
performant wise they are the same.
thing is, you want the same base in a loop, so if you have copper, you go with the simple acetal, if you have the nickel, you go to the acetal+nickel.
Ah I see Im getting the ek predator 360 so best just going with copper?
yes i do believe the new AIO from EK has copper base, so you should go with the acetal version.
Just double check to make sure.
