It's not been recalled twice at all. First issue with the banding was captured before stock was distributed. Sure it delayed launch a bit but was caught early. Only a very small amount of early stock was released earlier in Germany. This waking from sleep issue is still not a massive problem in my opinion. You make it sound like they are recalling everyone's screen they've sold so far. Absolutely not. They are offering the option to return it via their support teams if it causes you a problem for a fix. It's not even something that would affect everyone at all anyway
Recalled twice, once when it was RELEASED in Germany, then OCUK got stock, they was about to send it out, then it got a recall. Then we have this recall, ACER has stopped selling products to the retailers to update it. This means it is a recall, for firmware update V2, this is not even fixing the lines on the monitor at low FPS when Gsync is on.
Also managers at retailers are receiving emails about this recall
"Instead Acer has identified that a hardware level remedy is required. So currently our repair and contact centers are being brought up to speed to assist."
This shows it is a hardware level fault, this could effect longevity of the monitor.
Well part of the reason why the monitor market has so many faults in it is because reviews just skip over theses issues. If reviewers actually reviewed the product, showing the negatives then it would effect sales and will produce a fix faster, as reviews come out before the monitor.
Also you could say cherry picking is another issue. If you had the sleeping issue, it is a fault, should have been listed. Linus did not even give one fault on the monitor, many people messaged him about it.
You know how many problems this monitor has with it, these include:
Sleeping issue
Screen flickering
Not reaching 100hz
Coil whine
Colour banding (is fixed, however still happened)
Settings being reset
Colour changes when the monitor is turned off (you have to unplug it)
Lines on screen
You cannot tell me, these are "small issues" that are being over exaggerated on the monitor.
Now before I get the comment from someone, no, I am not an ASUS rep, if you look at what hardware I have, you will know I am not (I do not use any ASUS hardware inside my computer) an ASUS rep
Also there are only two 3440x1440p 34 inch Curved 21.9 100hz Gsync monitors coming out soon, the ACER Predator X34 and the ASUS PG348Q, between the two of course I would get the ASUS PG348Q
It seems ACER did not even test this monitor with the amount of issues on it. They just rushed it to be first with it. This is not the first time ACER has done this, the ACER 1440p has terrible QC as well
So overall, this monitor monitor needs fixing and should not be recommended until it happens.
Thanks for reading
