So keep the old locks and keys and when you move out put them back? They won't be any the wiser.
Thought: if you had changed the locks and didn't tell anyone - wouldn't that expose the intruder? Assuming:
1) The agency need to let you know when they are gaining access
2) The agency need to let you know when the landlord requires access
Who else needs to get in besides yourself?
BB x
I wish I did just change locks without letting them know. I am too honest and thought contacting them was just the right thing to do.
The front and back door locks look similar to this:
And I know someone has definitely entered the front door, due to the way the front door was locked. It wasn't locked how I usually lock it.
Ergh no wonder landlords get a bad rep.
I don't understand the justification of charging you to change your own locks.
Because "The landlord changed them when you moved in".
Any report I make it appears that the excuse and the non-urgency reply is "It was fixed before".
Load of ******** though. As long as you don't throw away the old set and refit them when you leave I can't imagine they have a leg to stand on. The landlord doesn't have any associated costs with you changing them yourself.
Have you spoken with a legal advisor?
Not yet, that is the next step. But I am quite busy this month with work over this period. Being Christmas and all. I cannot afford to be taking time off work. But I shall be taking this further for sure, especially if they don't pull their finger out.
How much further can I go? - Are there people higher up then themselves?
Just to add Martin&Co is a franchise operation so experience at one is not necessarily the same as experience at another.
(it probably is though because they're a letting agent and in my experience all letting agents are equally bad)
It's best to name a specific branch so people know which one when posting comments about them![]()
