 - 26 Sep 2013
 - West End, Southampton
lol you noob Arch
Can i uninstal the vpn once the game is unlocked?
FFS...
How did I miss that!!!
If you do, make sure you open steam in offline mode once you disconnect from the VPN otherwise it'll go back to "PRE-LOAD" rather than "PLAY".
because 4 points in intelligence is too low![]()
I did find a proper bug though actually.
I have 2560x1080 and there is no resolution option for that. If I untick Windowed mode then the dropdown box with the resolutions goes blank/empty and I cannot pick any resolution. If I start the game without Windowed Mode then it goes to 800x600.
I cannot go 1920x1080 Windowed and then use ALT Enter as it doesn't do anything.
Its not a bug, It does not support widescreen natively. A small tweak in the files works. You need to run the game once. the find a the following folder: Fallout4Prefs.ini in
C:\Users\USERNAME\Documents\my games\Fallout4\Fallout4Prefs.ini
Find the following 4 lines and set up like so:
bBorderless=1
bFull Screen=1
iSize H=1080
iSize W=2560
Ultimately - I cannot play in Full screen at any other res than 800x600.
Motion blur off or on ? What you all picking ?
Is there an FOV fix then?
Scrolling out into the first zoom of third person is what it should be like!
