- 11 Mar 2008
- Norn Iron
happened once for me, restarting game fixed it, failing that roll back to the earliest prev save
The desperation to prove its rubbish and flawed is baffling.
Anyone else having the issue where you can't leave a terminal?
Have followed internet advice and capped game at 60fps using Riva Tuner.
Go to corvega assembly plant in lexington, go up on the plant and look at the town.. sub 30 fps amazeballs cinematic gameplay experience, cue oooooobisoooft.
Slightly annoying I can't overclock without it crashing seems really sensitive. At stock gpu clock it's rock solid it seems.
A bit off topic but I'll ask anyway.
Never played FO3 much. Did it age well? Still worth playing?
Anyone finding it too easy, or does it get more difficult later on?
Playing on normal its been pretty easy. You can always adjust the difficulty in game if its a bit too easy though.
Cheers, must have missed that.![]()
Survival is well worth playing if you're comfortable with the game.
I have found the opposite, everyone I seem to meet at the moment has a skull next to their name, even raiders I need to use half my ammo to kill them (multiple headshots with shotgun doesn't kill them etc!)
I have just for a powerfull 10mm pistol which seems to do more damage, but I changed it to easy to get through some areas!
Is there a 'showfps' command via the console?
My game has been running like a dream at 1920x1080 on my positively ancient rig of i7 920 D0 @4.0Ghz, 16 Gb RAM and GTX760. That said, although I've got everything set to Ultra (from the Launcher anyway) the textures look pretty guff now and again, especially up close.
I'm not sure, though I expect there is. You could just use MSI Afterburner?
