Never understood unplugging things from the wall after switching them off at the wall. The circuit is broken hence no power when it is off so what will unplugging it do.
The "Live" is broken.
The "Neutral" is still connected however.
If you are unlucky and the local ****** have had a go at your supply substation the "Neutral" can (worst case scenario) go right up to 440 volts!
Peoples houses have actually burned down as a consequence of this!
tbh no excuse for my ignorance but i do still live with them hahaha.
would not really have suited me if i did leave it the way i change it as the boiler is in my room and it would wake me up turning on and off so often...
it is common sense but until i asked i thought it would be something like - what i did reduced the life of the timer from 20 years to 19 years and 8 months.
Ok let's put it into simple language you may understand.
You decide to turn your computer on because you want to look at something on the internet for 15 minutes and then turn it off.
15 minutes later you decide to turn it on again because you want to email a couple of people for 15 minutes.
15 minutes later you want to look at some porn and then turn it off again after 15 minutes
and so on ...........................................
You must now realise that it can't be good for the PC to keep doing this?
spent many a happy weekend in 70s and 80s at my grans house , but every night without fail she unlugged the tv from the wall , just in case it caught fire lol god bless her![]()
Or do what I do and turn it off.
Nothings cheaper than a jumper.
Isn't that what windows updates do though. If not windows updates I've seen it with something on the computer tell me it will restart a few times.
In the 1970s this was a realistic fear.
Aye, valves got hot, QC on the circuit boards wasn't always great and they used wirewound transformers and other parts that could degrade quite alarmingly.
I seem to remember that faulty TV's were a fairly major cause of house fires (at least electrical ones) back in the 70's.
Rather like cheap chinese mobile phone chargers today really.
