php - create array in while loop - can't figure it out
12 Feb 2006
Surrey
why isn't the below working? the array is being created and returned, however it's just the latest while loop that gets returned. i've tried $timeoff .= array.... but that messes it up. how would i add to the array without resetting it?
PHP:
$timeoff = array();
   while($row = mysqli_fetch_array($result_stafftimes_timeoff)) {
$offId =$row['offId'];
$location =$row['location'];
$startdate =$row['startdate'];
$enddate =$row['enddate'];
$reason =$row['reason'];
$timeoff = array
  array($startdate,$enddate,$reason, $location),
  return($timeoff);
Alternatively you should be able to do -
Code:
$timeoff[] = array($startdate, $enddate, $reason, $location);
Edit - I should have added a bit more info but essentially the code you have creates a new empty array using the $timeoff variable then during your while loop you assign the variable with a new multidimensional array (array( array() ); rather than to an index, which is why you're only seeing the last results.
Using square brackets after an arrays variable denotes that you want to assign a value to a new index, eg - $array_variable[] = 'Bob'.
Where array_push() is useful is when you need to add data to multiple indexes at once, otherwise i'd just stick to the above for simplicity.
I would however recommend reading the PHP 'sites documentation as there's loads of examples - http://php.net/manual/en/language.types.array.php#language.types.array.syntax.modifying.
