Splitting Game Recording Files.
Caporegime
8 Nov 2008
Hi,
Some of my ShadowPlay file sizes are too big to be transfered, e.g. to my memory stick. What methods are there for breaking them down into smaller files?
Ta. :)
Keys?
I'm using Windows 7 (need to change my signature), so isn't that NTFS?
I hadn't thought of 7zip; cheers, I'll check it out. :)
By keys he means USB stick / usb key..
If it's formatted as FAT32, then it won't allow filesizes over 4GB. You didn't answer his question, how big are these files?
Do you need them as a RAW files, what format are they?
Can you shrink them down with handbrake to MP4/MKV files? Or do you want them as they are.
7zip will split them into multiple smaller files, but might not be the best option, depending what you want to do.
7-zip as above.
Also, I think you can set a split size on ShadowPlay, so might be a good idea to do that for future? Only problem with that I suppose is re-joining which is more difficult with a video file compared to a zip.
Thanks. Yes, I did wonder if that is what it means.
Most of the ones I wanted to transfer are 4gb or under, so they are no problem, but there are about 7 or 8 files which range from 5-6gb to around 35gb.
A vast majority of them are in MP4 format. I suppose it would be better, though not imperative, if they were left as is.
I haven't tried splitting any of the files just yet. I'm sure it's not a particularly difficult exercise, though I don't believe I've ever done it before.
Yeah, I did have it set up to automatically keep the files below the 4gb threshold, but thought it made more sense to keep the recording as one larger file. Now I know it's not always the best way. :)
Okay, I've split one of the big files.
Do I need to use handbrake to convert to so it can be played / edited, as the file type now says .001?
Winrar or still 7zip?
Thats just a file archive part no. it should be possible to extract a single file from the numbered archive file chunks certainly thats true for WinRar
Basically it sticks it into an archive, chopping the archive up into chunks as it goes which you distribute separately bring the chunks together at the other end run the archive tool and/or self-extractor and it'll extract an as-original single file from the archive
I edit my videos with VideoReDo which can then convert as well to any file format and shrink down if needed
