**THE NVIDIA DRIVERS THREAD**
NVIDIA GeForce 359.00 WHQL Driver Released, Game-Ready Driver For Assassin’s Creed: Syndicate
Game Ready
Assassin’s Creed: Syndicate and Overwatch: Beta.
GameWorks VR 1.0 Support
Driver support for GameWorks VR 1.0, including Multi-Res shading and Windows 10
support.
Application SLI Profiles
Added or updated the following SLI profiles:
• Guild Wars 2 – 64-bit EXE added
• Overlord: Fellowship of Evil – DX11 SLI profile added
• Total War: Attila – SLI disabled
• War Thunder – 64-bit EXE added
3D Vision Profiles
No 3D Vision profiles were added with this release.
Software Modules
• NView – version 146.78
• HD Audio Driver – version 1.3.34.4
• NVIDIA PhysX System Software – version 9.15.0428
• GeForce Experience – version 2.7.4.10
• CUDA – version 7.5
http://www.guru3d.com/files-details/geforce-359-00-whql-driver-download.html
or
http://la.nvidia.com/download/driverResults.aspx/95695
I wonder if they aren't found on all searches as they don't work with all cards?
They won't install on my GTX980 as the installer just says 'installation cannot continue' regardless of whether I do a clean install, a normal install or do a complete wipe with DDU and then install them from scratch.
Any other 980 users having issues installing these on the latest version of win 10 pro x64?
First method causes glitches in the menus and computer terminals.
Found this -
Actual SLI Fix that Works, Tested on x2 Maxwell GTX970 in 4K, Windows 10 Pro, 64Bit.
Please see screenshot for FPS Gain.
Method #1 (Maxwell)
SLI compatibility bits (DX1x): 0x080200F5 (Max Payne 3)
Number of GPUS to use in SLI rendering Mode: Choose how many GPUs you have in your system
NVIDIA Predefined number of GPUs to use on SLI rendering mode in DirectX10: Choose how many GPUs you have in your system
NVIDIA Predefined SLI mode on DirectX 10: SLI_PREDEFINED_MODE_DX10_FORCE_AFR2
Method #2 (Maxwell)
Out friend here user named 'hide291', mentioned an alternative method for Nvidia Maxwell GPUs (I can confirm that it works).
Open up Nvidia Inspector, Open Fallout 4 Profile, use the button to Reset it to Nvidia defaults and change just one setting:
SLI compatibility bits (DX1x): 0x080000F5 (Killing Floor 2, Catzilla, Dragon Age 2)
Use something like Frap to see FPS and compare which method works best for you.
Method #3 (Pre-Maxwell)
Its been reported that this method works for some people with Kepler Generation cards (600 Series), user 'Johnsenpai' says that it works on his SLI670, but that also my first method works a little better.
This is the one that fakes SLI on Maxwell, if you enable nvidia SLI indicator and enable this method on Maxwell it will look like both cards work but if you compare FPS to single card mode, it wont be any better.
Go to NVIDIA Control Panel and change SLI Rendering Mode to Force Alternate Frame Rendering 2
Video of it also.
Just a quick update, the problem that I was having was related to my firewall blocking connection attempts by the installer
