The cable i bought does seem a bit loose at the card end compared to the one that came with the monitor. But when i used it i had the refresh rate being locked issue. First a max of 24Hz, then 85Hz.
Ill have to get it from the loft as i mistakenly left the supplied cable and power brick in the box. System has been on since 9.00 this morning and no issues so far.I know it'll lock you at 85Hz, but maybe try the other cable and see if the issues go away? Then you'll know if it's cable quality...
It's shocking
I've only just gotten up to speed with this thread. Has anyone has theirs repaired? And what is usually the turnaround time?
Quite a few have had to RMA them going by this thread. Iirc, Dicehunter has stated that he's been through 7 swifts. Support from asus doesnt seem to be that great either.
I'll be monitoring my RMA like a hawk (new psu required). Gave them a call yesterday in response to their automated email suggesting a full panel replacement will be booked in. He assured me it'd just be a psu that would be sent out and he'd contact the RMA team instructing them to do so. Will see what happens and I'll post my experience here. I'll be sure to name and shame them where I can if it all goes wrong![]()
I'll certainly think twice about buying anything from Asus again based on what I've seen here. Waste of time.
I'm struggling to believe at this point anything other than that the majority of panels rather than the exception are destined to die - been asking around a bit and pretty much everyone I know who has/does own one has RMA'd it atleast once - including those with the newer 2015 panels that were supposedly more reliable.
Anyone suffering from vertical line interlacing issues on fast moving objects?
I'm on my 4th Swift, bought on release day.
However, my friend bought one about a month later and his has been perfect, so there certainly are some that don't die.
