I remember reading somewhere the dual-slot recording doesn't work properly on the 0806. Try with just the one card in slot B FreeStream.Fills both 128GB cards. Might turn off the motion detection and turn off auto power off and just let it record.
If you look at the comments on the mini0806.com website it seems I'm not the only one.
Also where did you buy yours from? Is it version 3?
I vaguely remember reading about this also. The connection gets looser over time. Can't remember if there was a recommended fix - probably need to jam something in.Has anyone with an 0805 (or 01/03/06, assuming they use exactly the same mount) noticed that the red 'charging' light flickers because of seemingly poor contact to the GPS/charging base? It does seem a bit wobbly.
It doesn't seem to affect its operation at all, but I feel I should sort it. I guess I just need to make the camera>base fit a bit tighter.
for extra points.
