Or you're just getting owned.Getting completely owned at times. Must be controllers in use.
God, coming off several years of Battlefield, it's so refreshing to not have this.What really winds me up is the inability to select a server for a certain map, frustrates me massively. What is their problem with that, why can't they do it?
. Made it to wave 28 in the end. If anyone has got to the flag part of the Easter egg, its pretty crazy!Can any answer this. I got a copy of this via cdkeys and it seems i have the version with out nuketown.
How do i go about getting nuketown i am guessing season pass ?
Anyone else getting lots of lag in mp? Seems every other game or so.
Also domination is just an exercise in frustration, if you have a and b, dont all run off to c leaving b for an easy take. Argghhhhh!
People can't get to grips with the fact you dont need all 3 flags.
There is two versions on cd keys. One with out Nuketown and one with. So i am fully expecting to have to get the season pass.
Kinda annoying. And yes annoying lag from time to time also.
I made the same mistake, bought just the game and then realised the game + nuketown was only £1 more, I didn't see it though before buying just the game :/
You'll need the season pass now in order to buy it.![]()
Anyone here with a mic fancy teaming up to do some zombies?
Round 33 last night and decided to end it all as it was 3am.
Started off just trying to stay in the first area for as long as poss, then after 8 rounds decided to go do the PAP etc...
Must have spent a million on the mystery box before finally getting little arnie.
New strategy, hold off in front of a portal for as long as poss then back up through into PAP area, rinse and repeat.
Finally got the build-able wonder weapon also.
Using the PAP haymaker with turned attribute, and dingo as primary weapons
