FX-8350 Cooler
It does if you have low profile ram your fine. I have corsair vengeance ram which no longer have the heatsink on them. I am planning an upgrade to faster ram next year as it's only 1600mhz so will buy some low profile ram and then refit the heat sinks to the vengeance ram for going into the amd machine
God it looks so big
:eek:
Yea there a fair chunk of a thing but the results speak for themselves. As I say it does a better job than the H80i and gives me piece of mind. And I must admit I actually like the look of it.. I'm tempted to try and get the raised lettering painted silver or black so it stands out
I've got the NH-D14 and it's huge, but gets the job done. It just depends if you like the Noctua beige/brown colour scheme on their fans. Performance wise, I can't complain and for something that big, it was very easy to install.
I can live with it. I never see that much of the inside of my case so the colour scheme wont matter to me.
This one, it is big but quiet and very efficient with a 38mm x 140mm fan at low rpm. It does not cover the Ram slots either.
https://www.overclockers.co.uk/silverstone-sst-he01-heligon-cpu-cooler-hs-005-sv.html
Thanks for all the suggestions guys. I went with the Thermalright Macho X2 Limited Edition in the end
