- 6 May 2015
EK Water Block and backplate for GTX 980 Ti
Thanks to EK Water Blocks for sponsoring Project Eris. Here are some of the main components that will form the watercooling loop.
The EK water block for the MSI GTX 980 Ti Gaming 6G is the EK-FC980 GTX Ti TF5 - Acetal + Nickel. This is paired with a custom backplate featuring the MSI dragon. This was made by Coldzero.
For cooling the CPU, the high-performance EK-Supremacy EVO - Nickel water block will be installed.
Finally the pump that will power the watercooling loop, is the EK-XRES 140 DDC PWM.
