The AMD Driver Thread
Should not stop you updating the OP and still doing a proper post here anyway.
Checking out the driver at the moment myself :D
Yep will do. I'm compiling the release notes for a post format. They are quite long time time, as you can imagine.
AMDmatt, Witcher 3 crossfire appears to be broken with the crimson driver. The cards are running but fps is now 41 fps where it was 60fps locked. Single card is 35fps as it was before.
AMD Radeon™ Software Crimson Edition
Highlights of AMD Radeon Software Crimson Edition
Hello everyone,
Click hereto download the driver.
Radeon Software Crimson Edition is AMD’s revolutionary new graphics software that delivers redesigned functionality, supercharged graphics performance, remarkable new features, and innovation that redefines the overall user experience.
Radeon Settings:
Radeon Settings is the new, streamlined user interface, engineered to bring out the best of AMD graphics hardware. User‐friendly and feature‐rich, Radeon Settings is lightning fast and starts upto 10x times faster than the previous AMD Catalyst™ Control Center. Radeon Settings provides a brand new game manager, improved AMD Overdrive options per game and new video, display and Eyefinity tabs.
New Install UI:
The driver installer now provides a brand new, streamlined user experience with a reduced number of clicks required, providing better usability and an easy to install user experience.
Liquid VR:
The AMD Radeon Software Crimson edition is the first publicly available driver that enables all LiquidVR features, which are currently being validated and tested by VR headset manufacturers and ecosystem partners.
Asynchronous Shaders:
A feature that has been extensively used by game console developers is now available to PC Gamers. Asychronous Shaders break complex serial workloads into smaller parallel tasks, thereby allowing idle GPU resources to be used more efficiently and parallel workloads allow taskes to be completed much faster.
Shader Cache:
The shader cache feature allows complex shaders to be cached, thereby resulting in reduced game load times, lower CPU usage and significantly reduced stuttering and latency during gameplay.
Optimized Flip Queue Size:
The optimized Flip Queue Size provides users with the very latest keyboard and mouse positional information during gameplay to reduce input latency on DirectX 9® , DirectX® 10 and DirectX® 11 applications. This feature is a driver optimization, therefore it is automatically enabled and requires no user configuration or setup.
Freesync™ Enhancements:
Minimum/Maximum display rate is now listed in Radeon Settings
Low framerate compensation to reduce or eliminate judder when application FPS falls below the minimum refresh rate of an AMD Freesync™ enabled display
New support for AMD Freesync™ with AMD Crossfire™ in DirectX 9® titles
Custom Resolution Support:
This feature provided users more control over display capabilities allowing the user to create custom display profiles to attempt to drive their display with chosen resolution, timings, refresh rates and pixel clocks.
Frame Pacing Enhancements:
Frame pacing support is now extended to DirectX® 9 titles.
Frame Rate Target Control Enhancements:
FRTC enhancements include: power saving capability, support for DirectX® 9 titles and an extended range for target control (30 ‐200 FPS).
Updated Video Feature support for 'Carrizo' products:
FluidMotion for smoothing playback of 24/30 FPS video using Cyberlink PowerDVD 15 for Blu‐Ray playback
Improved edge enhancement for sharper images Improved de‐interlacing for interlaced content
Power Optimization:
Improved power optimizations for video, gaming and FRTC enabled gaming environments (AMD Radeon™ R7 360, AMD Radeon™ R9 380, AMD Radeon™ R9 390 series and AMD Radeon™ Fury series)..
Directional Scaling:
Enhanced image quality for 1080p media content scaled to 4K resolution using adaptive directional filtering technology (AMD Radeon™ Fury products).
Dynamic Contrast Update:
Qualative changes are now content adaptive and provides video enthusiasts with improved video quality and contrast settings (AMD Radeon™ R8 285, AMD Radeon™ R9 380 and AMD Radeon™ Fury products).
DisplayPort to HDMI 2.0 support:
Provides full support for DisplayPort to HDMI® 2.0 connections via certified dongles.
Resolved Issues:
GTA V ‐ game crashes with a TDR error
Final Fantasy XIV: Heavensward ‐ game crashes when run in DirectX® 11 mode on some AMD Radeon™ R9 390x series products
The AMD Radeon Settings application will use the system default browser when launching web content
A crackling noise is heard when running a 3D application in AMD Crossfire™ mode with Vsync enabled
Autodesk Max 2016 ‐ A crash may be experienced when launching the application on some AMD Radeon™ products
Prepar3D® ‐ A TDR error may be experienced when launching the application on some AMD Radeon™ R9 200 and AMD Radeon™ R9 300 series products
A TDR error may be experienced when playing fullscreen video using the Windows® 10 Movies & TV app on some laptops with AMD processors and GPU's
Assassin's Creed Syndicate ‐ Poor scaling may be experienced when launching the game in AMD Crossfire™ mode
Secondary adapter may display error code 43 when enabling/disabling AMD Crossfire™
AMD Freesync™ does not function on some Intel + AMD laptop systems under Windows® 7 and Windows® 8.1
Assassin's Creed Syndicate ‐ Flickering may be observed on rain drops that fall on in game characters
A BSOD error may be encountered when launching Bluray / Windows Media Player with a wireless display
Skype ‐ The system may hang when connecting to a 1080p video call
Tom Clancy's Rainbow Six Siege ‐ Random corruption may be experienced in‐game
AMD Freesync™ does not function if a Youtube video is playing alongside a 3D application
Issues Resolved since AMD Catalyst 15.7.1 and included in this driver
Ashes of the Singularity™ may fail to launch on some GPUs with 2GB Video Memory.
Driver installation may halt on some configurations
Some BENQ 144hz Freesync™ monitors may lose the signal while uninstalling the driver
Anti‐Aliasing settings not being retained after changes are applied
DiRT Rally™ crashes during gameplay and benchmarking when launched in DirectX® 11 mode on some BENQ 144HZ Freesync monitors
Assassin's Creed® Unity may experience minor frame stutter when AMD CrossFire™ mode is enabled
World of Warships may crash on some AMD Radeon HD5000 and HD6000 series products
The DirectX® Diagnostic tool does not report DirectX® 12 available on supported products
Dragon Age: Inquisition may crash if launched in Mantle mode
The AMD Catalyst Control Center 'update' option fails to download the latest driver
Ashes of the Singularity™ ‐ A 'Driver has stopped responding' error may be experienced in DirectX® 12 mode
Diablo 3 crashes in the Act 2 Desolate Sands area of the game
A TDR error may be experienced while toggling between minimized and maximized mode while viewing 4K YouTube content
Intermittent playback issues with Cyberlink PowerDVD when connecting to a 3D display with an HDMI™ cable
Star Wars™: Battlefront is able to use high performance graphics when launched on mobile devices with switchable graphics
A TDR error is experienced when launching Star Wars™: Battlefront while a You Tube video plays in the background
The secondary graphics adapter is missing in the Device Manager and the AMD Catalyst™ Control Center after installation of the driver
A TDR error or crash is experienced when running the Unreal Engine 4 DirectX® benchmark
Video playback of MPEG2 video fails with a playback error/error code message
Ashes of the Singularity™ may crash on some AMD 300 series GPUs
An error may be experienced when installing the latest graphics driver package on some AMD Radeon™ R9 380 series products
The Intel graphics is flagged in an error state in the Device Manager in systems with switchable graphics
The Oculus runtime may crash on launch
BSOD observed when performing an express uninstall of the display driver in 4K resolution
Battlefield™ Hardline becomes unresponsive after toggling the in‐game Vsync option.
Transcoded clips may fail to play on some Drag and Drop devices
Audio driver is banged out for non‐primary ASIC after enabling CF and rebooting system
3DMark Farandole may crash when AMD Mantle is selected from the test suite
A ‘missing Dll’ error message may be experienced while doing an express uninstall of the current driver
DLL missing popup message may be encountered when performing an express uninstall of the display driver.
Mantle‐based application may crash when system is woken from sleep mode
A crash may be experienced on some AMD Radeon™ R9 300 series products while running the Unigene benchmark
Battlefield™ 4 may crash if run in Mantle mode with AMD Crossfire™ enabled
Cyberlink PowerDVD plays 3D content in 2D mode
With quad AMD CrossFire™ mode enabled, TDR or blank display occurs when launching DirectX® 9 application in full screen
Flickering corruption may occur in Dirt Rally™ with Advanced Blending enabled
Corruption may occur in DiRT Rally™ with CMAA enabled with Portrait SLS and AMD CrossFire™ mode enabled
Intermittent BSOD occurs when launching a race in Dirt Rally™
Display profiles are not retained after driver upgrade from 14.502 to 15.20
Some “Kaveri” APU‐based systems may experience minor performance drop on PCMark8® video_group_chat & Casual Gaming tests
Battlefield™ Hardline crashes on pressing Ctrl+Alt+Del while running in AMD Mantle mode
Some systems experience a minor performance drop from 15.15 to 15.20 in The Witcher 3: Wild Hunt with HairWorks enabled
Unable to apply Fill mode in Eyefinity if 2560x1600 and 2560x1440 resolutions are used together
Unable to create an Eyefinity SLS if one of the displays is a MST display device
Windows 10 driver installation may halt on some systems with an AMD 990FX chipset and AMD CrossFire™ enabled.
Some BENQ 144hz Freesync monitors may lose the signal while uninstalling the driver
DiRT Rally™ crashes during gameplay and benchmarking when launched in DirectX 11® mode on some BENQ 144HZ Freesync monitors
Mad Max ‐ Color corruption is observed when Alt+Ctrl+Del is pressed followed by the Escape key
Known Issues:
Dirt Rally ‐ A crash may be experienced starting a new race with AMD Crossfire™ and AMD Freesync™ enabled
PowerDVD ‐ 3D playback may fail on some configurations using an HDMI 2.0 dongle
Starcraft 2: Flickering may be observed in the 'Episode 3' campaign
Fable Legends: The DirectX® 12 benchmark may fail to launch on some configurations
Call of Duty: Black Ops 3 ‐ Flickering or poor performance may be experienced when running in AMD Crossfire™ mode
Assassin's Creed Syndicate ‐ A crash may be experienced when setting game to Ultra‐High graphics mode
Flickering may be observed on some Freesync monitors while playing Wolfenstein ‐ The New Order and Battlefield™:
Hardline with Vsync disabled
A system restart may be experience when waking the system from sleep mode on some systems with Intel processors
Unable to create 4x1 or 2.1 portrait mode SLS with 4K displays
Star Wars™: Battlefront ‐ texture corruption may be experienced if the game "Field of View" setting is > 100
Call of Duty Online ‐ the game may crash if the Printscreen key is pressed on a 4K monitor
Launching a game from the Game Manager may launch on a single display after enabling and disabling AMD Crossfire™ in a 3x1 AMD Eyefinity™ setup
A crash may be experienced if an HDMI™ display is a cloned display device on an HP Envy 15 notebook
Unable to change resolution if a wireless display is the only connected display
Marginally increased power consumption may be observed during video playback
Flickering may be experienced on some monitors when AMD Freesync™ is enabled
Assassin's Creed Syndicate ‐ Building textures may be missing on some AMD Freesync™ displays with Vsync enabled
Ark Survival Evolved ‐ Poor performance may be experienced when running in AMD Crossfire™ mode
Star Wars™ : Battlefront ‐ Some flickering may be experienced in shaded areas of the screen while game levels are loading
Star Wars™ : Battlefront ‐ Some users may experience minor flickering or corruption at different game location or while viewing the in‐game cinematics
AMD Issue Reporting Form:
This driver release incorporates suggestions received through the AMD Issue Reporting Form. To provide us with your feedback, visit the AMD Issue Reporting Form.
'DisplayPort to HDMI 2.0 support:
Provides full support for DisplayPort to HDMI® 2.0 connections via certified dongles.'
Wow is that mean people can play games on a 4k tv via a certified dongles now?
So where can we buy this 'certified dongles' or any news of it?
I feel left out with this virtual super resolution. Says not supported for me! They should allow me to play 8K or something :p
Right, wonder if it'll show much use in BF3/4 then... as I'm getting over 130fps, and that seems excessive so may as well use some of this power then, will take a look at the options and see where to enable etc.
I used it in BF4 just to see if it worked and it did, but i just use the resolution scale built into in BF4.
